After upgrading my Bomebox firmware to 1.5.3 my test project running on my Mac no longer worked. I checked and unchecked the Automatic Routes box in Web Config and got a ‘spin’ icon, but nothing changed. I finally saw that all of my ports still showed as Closed. My project worked again after I made manual routes. I’m using Safari on Mac for Web Config. How do Automatic Routes work? Am I missing something? I’m just getting to know the BomeBox and Midi Translator Pro. This is my first post. Thanks for any help.
Typically when you are running a project file, the automatic routes are overridden by the routes within the project file unless you add other routes in manually after the project file is loaded.
I think that you should find if you stop the project, then check automatic routes, it will work again until you load a project file which again will override the BomeBox MIDI routing.
