Problem: The new midi controller I’m using is NOT multi-client ready.
So, having the Sequencer receiving both from BOME MT Virtual Out AND the same hardware midi controller itself - doesn’t work.
I have installed a virtual midi port software to be fired up both in BOME MT and the Sequencer. In that way, hopefully, I can set all the channel 2 messages to be sent (bidirectional) to that virtual midi Port X from BOME MT.
As the midi communication on channel 2 is bidirectional (Generic Remote), I need the Sequencer to be able to send the current state back, to preserve parameter jumping. Al that worked per default with my previous multi-client midi controller thanks to your Bome MT preset additions here on the forum.
Let us start simple: Can you please suggest a Bome MT preset that will automatically route (send) all channel 2 messaged to Port X?
Btw, shall I also create an Alias for Bome MT input for that?
Thank you in advance.
