Hi all, thank you for any advice given.
I have a BCF2000 and a MPD32. I have been using this setup for 6 years, using BC Manager for the BCF2000 and physical edits on the MPD32 for MIDI manipulation, also using the latest version of Bome's for simple on/off, inverted etc... MIDI messages in Ableton Live 10.
Now to my real question...
Im on week 7 of trying to figure out how rules and variables work, and for the most part I understand. But this "Master Template" that I'm trying to configure has got my brain in such a tight knot, idk what to do anymore. This mainly applies to the BCF2000. Inside BC Edit I have made all faders on one MIDI Ch1, all bottom row buttons are on Ch2, top row of buttons Ch3, pan Ch4, pan push Ch5. Ch6-11 are seperate Aux/Send levels per pan pot. MIDI Ch 12 being open, MPD32 on Ch13.
What I would like to have done is to be able to press "Encoder Grp 3" and have all 6 pan pots set to control Aux/send volume levels of the one selected track. I know this has to do with rules and global variables, I just cant seem to understand how to make it happen. In BC edit I have set pan pots 1-6 on a separate MIDI Ch(6-11), 7-8 are off. A problem is that I cant stay on the same BCF2000 preset and change send levels to any of the remaining faders. I would simply like to be able to pull up a fader, press "Encoder Grp 3" on the BCF2000, and any fader I touch, will show the current Aux/send level of the track. And if possible to use "Encoder Grp2" as the track select, and have the Aux/send levels follow whatever track that has been selected if I were to press "Encoder Grp 3"
f.y.i
Encoder Grp1 "Pan", Encoder Grp2 "Track Select",
Encoder Grp3 "Aux/Send Level", Encoder Grp4 "Open"
Thank you in advance for any help/advice given.
