shaunkerr
(shaunkerr)
January 14, 2021, 1:20pm
1
Im really keen to get started using Bome.
I have installed the Trial version. My Midi device is going to be the Elago Stream Deck.
Unfortunately, I am struggling at the 1st hurdle.
According to the manual I should be able to see my Midi device in the Project Midi Ports.
However, that is not the case.
Could I be missing something?
I have attached screenshot.
Thanks in advance for any advice.
Screenshot 2021-01-14 at 12.24.46|690x366
SteveC
(Steve)
January 14, 2021, 2:58pm
2
Hi, I don’t see MIDI on my system either for Stream Deck. It is possible that you may need to install a plugin. I haven’t tried yet but I see there is one that I can install. See screenshot below.
SteveC
(Steve)
January 14, 2021, 3:22pm
3
I had to install the plugin and then stop and restart StreamDeck and now it works fine.
StreamDeck does not include virtual MIDI ports but you can you can use a Bome MT Pro virtual MIDI port if you are talking with MT Pro.
shaunkerr
(shaunkerr)
January 14, 2021, 4:01pm
4
Thanks for your reply Steve.
Unfortunately, Im on Mac and this is a Windows plugin.
SteveC
(Steve)
January 14, 2021, 4:07pm
5
OK, so I guess this is something to discuss with StreamDeck.
