Hi there,
I bought Bome MT to use my Macbook Pro keyboard for controlling a video mixing / VJ software via keystrokes. It was super easy to setup the keystrokes and I am able to control the software with the intended keys on my laptop which is great.
However, here is my problem and question:
Everything works well when MT Pro is active and in the front. Once I leave MT and switch to another app, let’s say I open an email, click on the desktop - or I mouseover the VJ software (fullscreen), MT stops sending keystrokes to MIDI out (and everything else seems to be inactive too - the indicator lights in the event monitor don’t blink anymore when I hit the assigned keys). When I click on the MT Pro app window again everything is back to normal and it recognizes keystrokes and sends MIDI.
So my question is: Can MT Pro receive keystrokes and send MIDI when it’s not in front? Is there a setting to tell MT Pro to send MIDI when a key is pressed no matter what – also when another app is active? I want project and preset to be running at all times.
Thanks for your help,
Alex
