I’m trying to get my Behringer CMD DV-1 to work with rekordbox 7. I’ve managed to get some buttons working but no luck with the LED feedback, and I can’t seem to find any downloadable Bome project files for this mapping disaster, I’ve spent months cracking my head on this but no luck.
According to this chart, to send LED feedback to the device, you need to send the same note-number it sends, but with a different velocity depening on the LED state that you want.
The LED state based on velocity is as follow.
0=off
1=on solid
2= blinking
I’m not sure how Rekordbox is programmed to provide feedback so I would probably need to you open the MIDI log window in Bome MIDI Translator Pro, check Incoming, Outgoing, MIDI IN and MIDI OUT and then share the results.
Note the the documentation talks about note number (IE “C2”) but the is not MIDI standard for note names. This could be note 24,36 or 48 depending on how the vendor names ther note numbers.
You might want to look at this post where I helped a user set up RekordBox with an APC-MINI MK2.
