Hello, I have a question in regard to getting midi feedback to the motorized faders on my Behringer Xtouch compact.
- Behringer Midi DIN in/out into Bomebox DIN
- Midi received by Resolume on a Mac and PC on the network.
- I move a fader on the Behringer and it triggers an endless midi feedback loop.
- the same happens when moving a fader on Resolume.
How should this be configured to avoid this?
Thank you,
S
SteveC
(Steve)
2
Are you running a MIDI translator Project on your BomeBox?
If not, have you looked at the routing page and turned of the automatic routes. You should probably not have a route from MIDI DIN In to MIDI DIN Out.
Maybe show screenshots of your routing page on BomeBox and if you are running a project, on it, can you share the project?
Hello Steve, thx for the reply.
I was using Translator Pro but in the end that just complicated things.
I stripped everything back to just input and output on the Bome network tool and it seems to have solved the problem?
Thx, S
