I've been working on using a launchpad Mk2 to control keyswitches in my DAW, and all is going really well (thanks for your help with switching lights on and off).
A simple question - Is it better to have multiple Presets or multiple translators or very long individual translators with lots of 'goto' instructions?
Which gives better performance ?
Here is an extract from one translator I've created (there are 1821 lines in the full version), and I'd be interested in knowing if it would be better to separate each sample set into either a different translator or different preset, or doesn't it make any difference (except in finding the right one to edit)?
if zn==hb then he=hb
//if zc==2 then gv=0
//Round button 1
if ic==104 then Goto "BBC SO"
//Round button 2
if ic==105 then Goto "VSL"
//Round button 3
if ic==106 then Goto "SYNCHRONSMARTORCHXP"
// Round button 4
if ic==107 then Goto "BIG BANG LOW BRASS"
// Round button 5
if ic==108 then Goto "BIG BANG HIGH STRINGS"
// Round button 6 with variation
if ic!=109 then skip next 2 rules
if id!=1 then skip next rule
if ic==109 then Goto "BIG BANG LOW STRINGS"
if id!=2 then skip next rule
if ic==109 then Goto "BIG BANG HIGH & LOW STRINGS"
if id!=3 then skip next rule
Goto "HISTORIC TRAVERSE FLUTE"
// Round button 7 WITH BUTTON variations
// if ic=110 and id = 1 then goto "SYNCHRONIZED SOLO VIOLIN"
//if ic==110 then Goto "SYNCHRONIZED SOLO VIOLIN"
if ic!=110 then skip next 2 rules
Goto "SYNCHRONIZED SOLO VIOLIN1"
//if ic==110 then Goto "SYNCHRONIZED SOLO VIOLIN2"
//if ic==110 then Goto "SYNCHRONIZED SOLO VIOLIN3"
// Round button 8
//if ic==111 then Goto "SYNCHRONIZED SOLO VIOLIN2"
Label "BBC SO"
//Triggered by round button 1
za=0
if hb==36 then za=1
if hb==36 then he=21
if hb==35 then za=1
if hb==35 then he=20
if hb==34 then za=1
if hb==34 then he=19
if hb==33 then za=1
if hb==33 then he=18
if hb==32 then za=1
if hb==32 then he=17
if hb==31 then za=1
if hb==31 then he=16
if hb==28 then za=1
if hb==28 then he=15
if hb==27 then za=1
if hb==27 then he=14
if hb==26 then za=1
if hb==26 then he=13
if hb==25 then za=1
if hb==25 then he=12
if hb==24 then za=1
if hb==24 then he=11
if hb==23 then za=1
if hb==23 then he=10
if hb==22 then za=1
if hb==22 then he=9
if hb==21 then za=1
if hb==21 then he=8
if hb==18 then za=1
if hb==18 then he=7
if hb==17 then za=1
if hb==17 then he=6
if hb==16 then za=1
if hb==16 then he=5
if hb==15 then za=1
if hb==15 then he=4
if hb==14 then za=1
if hb==14 then he=3
if hb==13 then za=1
if hb==13 then he=2
if hb==12 then za=1
if hb==12 then he=1
if hb==11 then za=1
if hb==11 then he=0
Goto "END"
Label "VSL"
//Triggered by round button 2
