Hello, I wanted to re use my stream deck again but I noticed that cubase did not recognize it because BMT was open and BMT was grabbing this device. No translator or preset use the stream deck virtual ports
If you close Bome MIDI Translator Pro, can you access your streamdeck from Cubase?
In Bome MIDI Translator Pro at the project level, see if either the input or output port of your streamdeck shows open and whether a checkbox is on. See illustration. Note, that I do not have a preset selected. I’m at the project level over at the left side of the screen
