Somethings not right if you get the UAC splash screen when opening in normal user mode. I would try and re-install it. You might want to check with Ableton.
I'm making my template but I'm stuck and I don't find answer on the forum;
I have translators which translate the jogwheel of maschine studio to up and down keys (two translators : one for UP turning the wheel right, one for DOWN turning it left).
I wonder if it was possible, pushing another button (pushing the jogwheel and sending a CC message) to transform these translators in toggle mode to right and left in place of up and down ?
I found on the forum some rules with pp,qq,rr,ga etc... But I cannot find the documentation about that, could you light up my candle ?
Not recommended, I’ve seen a few anomalies with MT Pro in Admin Mode. I think they have all been worked out but it is really designed to be used in normal user mode.
Show me the project file you have and what is working for left and right and what you want for up and down. It should be fairly easy.
There are 10 local variables. These are not seen outside of the the given incoming trigger so they can be used as variables within a translator. They, however cannot be seen by any translators using a different incoming trigger. These are best used for temporary variables since they are not shared outside. They are oo through xx (letters of the two are all the same.
In contrast, global variables can be seen throughout the project. There are 360 of these first letter starting with g-n and y and z. Second letter can be a-z or 0-9. If you need to share values across translators you use these. Usually only one or two translators modify the variables but everything else reads them. It is important to not modify them with multiple translators or they could bot be trying to update the variable at the same time which could leave it in an unconfimed state.
All of this is in the manual (F1 within MT Pro or the help menu)
