Recently, my Bome Box has stopped showing any available MIDI ports.
What steps can I take to troubleshoot/fix this issue?
Hi @Michael.Powell , and welcome to the Bome community!
I’m sorry you are having this problem!
First of all make sure you have reliable 5vDC power if you are connection to power via USB Micro port. Please ensure you are not connecting to a USB charging port on a USB hub as the power level for charging will be inconsistent. Try another USB port.
Make sure the power light on your BomeBox is on solid after starting it up. If it is blinking, then you are likely not getting persistent power.
Also make sure you unplug any USB devices to see if the MIDI DIN ports then show up. If they show up when the USB devices are disconnected but are not there, when the USB devices are connected, try a USB powered hub for any USB devices as they may be drawing too much power from the BomeBox.
If power does not seem to be the trouble, try installing the latest firmware upgrade again, to insure it completed successfully.
If this all looks good and you are still not seeing MIDI ports. Go to settings on BomeBox then to advanced configuration. You will then see a status menu and under that you can go to a page called kernel log. Please copy the text in the kernel log and paste it on this forum so we can take a look.
Oh and you might try doing a factory reset after downloading any project files you may have on your BomeBox that you need to keep.
Did this solve your issue?
thanks for your reply and for trying to help me out.
I’m using the BomeBox with PoE, power light is on solid after boot up. I tested powering with a 5V USB supply, found that the unit will not power on at all using USB power.
Nothing is plugged into USB-A port during testing. Running firmware 1.5.2
Kernel log shows the following
[ 0.000000] Linux version 3.10.49 (florian@chiaro) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r42067) ) #67 Mon May 31 13:33:59 CEST 2021
[ 0.000000] MyLoader: sysp=aaaaaa2b, boardp=aabaaaaa, parts=aaaaaaaa
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:40.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat 802ec690, node_mem_map 81000000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=BOMEBOX console=ttyATH0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 61400k/65536k available (2271k kernel code, 4136k reserved, 427k data, 244k init, 0k highmem)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.090000] NET: Registered protocol family 16
[ 0.100000] MIPS: machine is BomeBox
[ 0.550000] bio: create slab <bio-0> at 0
[ 0.560000] Advanced Linux Sound Architecture Driver Initialized.
[ 0.560000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.580000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.590000] TCP: Hash tables configured (established 512 bind 512)
[ 0.590000] TCP: reno registered
[ 0.590000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.600000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.610000] NET: Registered protocol family 1
[ 0.610000] PCI: CLS 0 bytes, default 32
[ 0.630000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.640000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.650000] msgmni has been set to 119
[ 0.650000] io scheduler noop registered
[ 0.650000] io scheduler deadline registered (default)
[ 0.660000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.670000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[ 0.670000] console [ttyATH0] enabled, bootconsole disabled
[ 0.690000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[ 0.690000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.700000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.700000] 4 cmdlinepart partitions found on MTD device spi0.0
[ 0.710000] Creating 4 MTD partitions on "spi0.0":
[ 0.710000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.720000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.730000] 0x000000050000-0x000000ff0000 : "firmware"
[ 0.750000] 2 uimage-fw partitions found on MTD device firmware
[ 0.750000] 0x000000050000-0x000000150000 : "kernel"
[ 0.760000] 0x000000150000-0x000000ff0000 : "rootfs"
[ 0.760000] mtd: device 4 (rootfs) set to be root filesystem
[ 0.770000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.770000] 0x000000710000-0x000000ff0000 : "rootfs_data"
[ 0.780000] 0x000000ff0000-0x000001000000 : "art"
[ 0.800000] libphy: ag71xx_mdio: probed
[ 1.350000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[ 2.390000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.940000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.950000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 2.960000] TCP: cubic registered
[ 2.960000] NET: Registered protocol family 17
[ 2.970000] Bridge firewalling registered
[ 2.970000] 8021q: 802.1Q VLAN Support v1.8
[ 2.970000] ALSA device list:
[ 2.980000] No soundcards found.
[ 2.990000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.990000] Freeing unused kernel memory: 244K (80303000 - 80340000)
[ 7.600000] usbcore: registered new interface driver usbfs
[ 7.600000] usbcore: registered new interface driver hub
[ 7.610000] usbcore: registered new device driver usb
[ 7.620000] exFAT: Version 1.2.9
[ 7.670000] SCSI subsystem initialized
[ 7.680000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 7.680000] ehci-platform: EHCI generic platform driver
[ 7.690000] ehci-platform ehci-platform: EHCI Host Controller
[ 7.690000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 7.700000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 7.730000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 7.730000] hub 1-0:1.0: USB hub found
[ 7.730000] hub 1-0:1.0: 1 port detected
[ 7.740000] ehci-pci: EHCI PCI platform driver
[ 7.750000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 7.750000] uhci_hcd: USB Universal Host Controller Interface driver
[ 7.770000] usbcore: registered new interface driver usb-storage
[ 7.780000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 10.390000] jffs2: notice: (323) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 17 of xref (0 dead, 2 orphan) found.
[ 15.530000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 15.550000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.560000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.570000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.580000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.590000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.600000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.610000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.620000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.630000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.650000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.660000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.670000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.680000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.690000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.700000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.710000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.730000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.740000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.760000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.770000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.780000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.790000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.850000] hidraw: raw HID events driver (C) Jiri Kosina
[ 15.850000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.870000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.880000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.890000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.910000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.930000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.950000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.970000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 15.980000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.000000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.010000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.030000] u32 classifier
[ 16.030000] input device check on
[ 16.030000] Actions configured
[ 16.030000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.040000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.050000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.060000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.090000] Mirror/redirect action on
[ 16.090000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.100000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.110000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.120000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.140000] nf_conntrack version 0.5.0 (963 buckets, 3852 max)
[ 16.140000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.150000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.160000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.180000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.200000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.220000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.250000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.260000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.280000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.300000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.310000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.330000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.340000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.350000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.380000] Failed to load ipt action
[ 16.390000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.410000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.420000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.430000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.440000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.450000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.480000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.500000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.510000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.530000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.540000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.550000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.570000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.590000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.600000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 16.640000] Bluetooth: Core ver 2.16
[ 16.650000] NET: Registered protocol family 31
[ 16.650000] Bluetooth: HCI device and connection manager initialized
[ 16.650000] Bluetooth: HCI socket layer initialized
[ 16.660000] Bluetooth: L2CAP socket layer initialized
[ 16.660000] Bluetooth: SCO socket layer initialized
[ 16.670000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.680000] Bluetooth: BNEP filters: protocol multicast
[ 16.680000] Bluetooth: BNEP socket layer initialized
[ 16.690000] usbcore: registered new interface driver btusb
[ 16.700000] usbcore: registered new interface driver cdc_acm
[ 16.700000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 16.720000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 16.720000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 16.770000] Ebtables v2.0 registered
[ 16.770000] Bluetooth: HCI UART driver ver 2.2
[ 16.780000] Bluetooth: HCI H4 protocol initialized
[ 16.780000] Bluetooth: HCI BCSP protocol initialized
[ 16.830000] hid_holtekff: module license 'unspecified' taints kernel.
[ 16.830000] Disabling lock debugging due to kernel taint
[ 16.840000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 16.850000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 16.850000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 16.860000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 17.000000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 17.000000] Bluetooth: HIDP socket layer initialized
[ 17.010000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.040000] lib80211: common routines for IEEE802.11 drivers
[ 17.040000] lib80211_crypt: registered algorithm 'NULL'
[ 17.040000] lib80211_crypt: registered algorithm 'CCMP'
[ 17.050000] lib80211_crypt: registered algorithm 'TKIP'
[ 17.050000] lib80211_crypt: registered algorithm 'WEP'
[ 17.080000] Bluetooth: RFCOMM TTY layer initialized
[ 17.080000] Bluetooth: RFCOMM socket layer initialized
[ 17.090000] Bluetooth: RFCOMM ver 1.11
[ 17.100000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 17.110000] usbcore: registered new interface driver ums-alauda
[ 17.120000] usbcore: registered new interface driver ums-cypress
[ 17.130000] usbcore: registered new interface driver ums-datafab
[ 17.140000] usbcore: registered new interface driver ums-freecom
[ 17.150000] usbcore: registered new interface driver ums-isd200
[ 17.160000] usbcore: registered new interface driver ums-jumpshot
[ 17.170000] usbcore: registered new interface driver ums-karma
[ 17.180000] usbcore: registered new interface driver ums-sddr09
[ 17.190000] usbcore: registered new interface driver ums-sddr55
[ 17.200000] usbcore: registered new interface driver ums-usbat
[ 17.220000] usbcore: registered new interface driver usbhid
[ 17.220000] usbhid: USB HID core driver
[ 17.240000] usbcore: registered new interface driver usbserial
[ 17.250000] usbcore: registered new interface driver usbserial_generic
[ 17.250000] usbserial: USB Serial support registered for generic
[ 17.330000] xt_time: kernel timezone is -0000
[ 17.340000] usbcore: registered new interface driver ark3116
[ 17.340000] usbserial: USB Serial support registered for ark3116
[ 17.350000] usbcore: registered new interface driver belkin_sa
[ 17.360000] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
[ 17.420000] cfg80211: Calling CRDA to update world regulatory domain
[ 17.420000] cfg80211: World regulatory domain updated:
[ 17.430000] cfg80211: DFS Master region: unset
[ 17.430000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 17.440000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.450000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.460000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.460000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.470000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 17.480000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 17.490000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.500000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 17.510000] usbcore: registered new interface driver ch341
[ 17.510000] usbserial: USB Serial support registered for ch341-uart
[ 17.530000] usbcore: registered new interface driver cp210x
[ 17.530000] usbserial: USB Serial support registered for cp210x
[ 17.550000] usbcore: registered new interface driver cypress_m8
[ 17.560000] usbserial: USB Serial support registered for DeLorme Earthmate USB
[ 17.560000] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[ 17.580000] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[ 17.600000] usbcore: registered new interface driver ftdi_sio
[ 17.610000] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 17.620000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 17.630000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 17.630000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 17.640000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 17.660000] usbcore: registered new interface driver keyspan
[ 17.660000] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 17.670000] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 17.680000] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 17.690000] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 17.750000] usbcore: registered new interface driver mct_u232
[ 17.760000] usbserial: USB Serial support registered for MCT U232
[ 17.770000] usbcore: registered new interface driver mos7720
[ 17.770000] usbserial: USB Serial support registered for Moschip 2 port adapter
[ 17.790000] usbcore: registered new interface driver oti6858
[ 17.800000] usbserial: USB Serial support registered for oti6858
[ 17.810000] usbcore: registered new interface driver pl2303
[ 17.810000] usbserial: USB Serial support registered for pl2303
[ 17.830000] usbcore: registered new interface driver sierra
[ 17.830000] usbserial: USB Serial support registered for Sierra USB modem
[ 17.860000] usbcore: registered new interface driver snd-usb-audio
[ 17.860000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 17.880000] usbcore: registered new interface driver ti_usb_3410_5052
[ 17.880000] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 17.890000] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 17.960000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 17.970000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 17.970000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 17.980000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 17.990000] usbcore: registered new interface driver qcserial
[ 18.000000] usbserial: USB Serial support registered for Qualcomm USB modem
[ 18.000000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 18.020000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 18.030000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 18.030000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 18.040000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 18.040000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 18.070000] ath: EEPROM regdomain: 0x0
[ 18.070000] ath: EEPROM indicates default country code should be used
[ 18.070000] ath: doing EEPROM country->regdmn map search
[ 18.070000] ath: country maps to regdmn code: 0x3a
[ 18.070000] ath: Country alpha2 being used: US
[ 18.070000] ath: Regpair used: 0x3a
[ 18.080000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 18.090000] cfg80211: Calling CRDA for country: US
[ 18.100000] cfg80211: Regulatory domain changed to country: US
[ 18.100000] cfg80211: DFS Master region: FCC
[ 18.110000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 18.120000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 18.120000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 18.130000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 18.140000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 18.150000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 18.160000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 18.170000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 18.170000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 18.180000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 18.180000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 18.210000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 18.210000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
[ 18.220000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
[ 18.230000] hid_holtekff: Unknown symbol hid_connect (err 0)
[ 18.230000] hid_holtekff: Unknown symbol hid_open_report (err 0)
[ 18.290000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
[ 29.310000] device eth0 entered promiscuous mode
[ 29.310000] br-lan: port 1(eth0) entered forwarding state
[ 29.320000] br-lan: port 1(eth0) entered forwarding state
[ 29.320000] br-lan: port 1(eth0) entered disabled state
[ 29.370000] device eth1 entered promiscuous mode
[ 29.370000] br-lan: port 2(eth1) entered forwarding state
[ 29.380000] br-lan: port 2(eth1) entered forwarding state
[ 30.380000] br-lan: port 2(eth1) entered disabled state
Hi Michael,
Could you set your firmware to system defaults? In addition to the kernel log, could you send the BomeBox log and the system log?
device has been reset to system defaults.
I found the system log, not sure where to find the BomeBox log?
SYSTEM LOG
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.440000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.440000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.450000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.460000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.470000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.480000] usbcore: registered new interface driver ch341
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.480000] usbserial: USB Serial support registered for ch341-uart
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.500000] usbcore: registered new interface driver cp210x
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.500000] usbserial: USB Serial support registered for cp210x
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.520000] usbcore: registered new interface driver cypress_m8
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.520000] usbserial: USB Serial support registered for DeLorme Earthmate USB
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.540000] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.540000] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.570000] usbcore: registered new interface driver ftdi_sio
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.570000] usbserial: USB Serial support registered for FTDI USB Serial Device
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.580000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.580000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.590000] hid_holtekff: Unknown symbol hid_connect (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.600000] hid_holtekff: Unknown symbol hid_open_report (err 0)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.620000] usbcore: registered new interface driver keyspan
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.630000] usbserial: USB Serial support registered for Keyspan - (without firmware)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.640000] usbserial: USB Serial support registered for Keyspan 1 port adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.640000] usbserial: USB Serial support registered for Keyspan 2 port adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.650000] usbserial: USB Serial support registered for Keyspan 4 port adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.720000] usbcore: registered new interface driver mct_u232
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.720000] usbserial: USB Serial support registered for MCT U232
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.730000] usbcore: registered new interface driver mos7720
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.740000] usbserial: USB Serial support registered for Moschip 2 port adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.760000] usbcore: registered new interface driver oti6858
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.770000] usbserial: USB Serial support registered for oti6858
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.780000] usbcore: registered new interface driver pl2303
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.780000] usbserial: USB Serial support registered for pl2303
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.790000] usbcore: registered new interface driver sierra
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.800000] usbserial: USB Serial support registered for Sierra USB modem
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.820000] usbcore: registered new interface driver snd-usb-audio
Mon May 31 11:34:46 2021 kern.err kernel: [ 17.830000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.840000] usbcore: registered new interface driver ti_usb_3410_5052
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.850000] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.860000] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.930000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.930000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.940000] hid_holtekff: Unknown symbol hid_connect (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.940000] hid_holtekff: Unknown symbol hid_open_report (err 0)
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.960000] usbcore: registered new interface driver qcserial
Mon May 31 11:34:46 2021 kern.info kernel: [ 17.960000] usbserial: USB Serial support registered for Qualcomm USB modem
Mon May 31 11:34:46 2021 kern.err kernel: [ 17.970000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.990000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 17.990000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.000000] hid_holtekff: Unknown symbol hid_connect (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.000000] hid_holtekff: Unknown symbol hid_open_report (err 0)
Mon May 31 11:34:46 2021 kern.err kernel: [ 18.010000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: EEPROM regdomain: 0x0
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: EEPROM indicates default country code should be used
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: doing EEPROM country->regdmn map search
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: country maps to regdmn code: 0x3a
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: Country alpha2 being used: US
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.030000] ath: Regpair used: 0x3a
Mon May 31 11:34:46 2021 kern.debug kernel: [ 18.040000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.060000] cfg80211: Calling CRDA for country: US
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.070000] cfg80211: Regulatory domain changed to country: US
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.070000] cfg80211: DFS Master region: FCC
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.080000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.090000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.090000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.100000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.110000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.120000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
Mon May 31 11:34:46 2021 kern.info kernel: [ 18.130000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.140000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.140000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.150000] hid_holtekff: Unknown symbol hid_connect (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.150000] hid_holtekff: Unknown symbol hid_open_report (err 0)
Mon May 31 11:34:46 2021 kern.err kernel: [ 18.180000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.180000] hid_holtekff: Unknown symbol hid_unregister_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.190000] hid_holtekff: Unknown symbol __hid_register_driver (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.200000] hid_holtekff: Unknown symbol hid_connect (err 0)
Mon May 31 11:34:46 2021 kern.warn kernel: [ 18.200000] hid_holtekff: Unknown symbol hid_open_report (err 0)
Mon May 31 11:34:46 2021 kern.err kernel: [ 18.250000] soundcore: exports duplicate symbol register_sound_dsp (owned by kernel)
Mon May 31 11:34:47 2021 user.emerg syslog: Error: Failed to connect to ubus
Mon May 31 11:34:48 2021 user.notice bomebox: WiFi LED OFF
Mon May 31 11:34:48 2021 user.emerg syslog: 'radio0' is disabled
Mon May 31 11:34:50 2021 authpriv.info dropbear[1206]: Not backgrounding
Mon May 31 11:34:52 2021 user.emerg syslog: Unknown group "netdev" in message bus configuration file
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Successfully dropped root privileges.
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: avahi-daemon 0.6.31 starting up.
Mon May 31 11:34:53 2021 daemon.warn avahi-daemon[1261]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Loading service file /etc/avahi/services/http.service.
Mon May 31 11:34:53 2021 daemon.warn avahi-daemon[1261]: socket() failed: Address family not supported by protocol
Mon May 31 11:34:53 2021 daemon.notice avahi-daemon[1261]: Failed to create IPv6 socket, proceeding in IPv4 only mode
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Network interface enumeration completed.
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Registering HINFO record with values 'MIPS'/'LINUX'.
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Server startup complete. Host name is BomeBox.local. Local service cookie is 587200112.
Mon May 31 11:34:53 2021 daemon.info avahi-daemon[1261]: Service "BomeBox" (/etc/avahi/services/http.service) successfully established.
Mon May 31 11:34:54 2021 user.notice bomebox: hotplug.net: action=add intf=br-lan dev=
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.280000] device eth0 entered promiscuous mode
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.280000] br-lan: port 1(eth0) entered forwarding state
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.290000] br-lan: port 1(eth0) entered forwarding state
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.290000] br-lan: port 1(eth0) entered disabled state
Mon May 31 11:34:55 2021 daemon.info avahi-autoipd(br-lan)[1281]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Mon May 31 11:34:55 2021 daemon.info avahi-autoipd(br-lan)[1281]: Successfully called chroot().
Mon May 31 11:34:55 2021 daemon.info avahi-autoipd(br-lan)[1281]: Successfully dropped root privileges.
Mon May 31 11:34:55 2021 daemon.info avahi-autoipd(br-lan)[1281]: Starting with address 169.254.8.243
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'lan' is enabled
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.320000] device eth1 entered promiscuous mode
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.320000] br-lan: port 2(eth1) entered forwarding state
Mon May 31 11:34:55 2021 kern.info kernel: [ 29.330000] br-lan: port 2(eth1) entered forwarding state
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'loopback' is enabled
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'loopback' is setting up now
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'loopback' is now up
Mon May 31 11:34:55 2021 daemon.notice netifd: Bridge 'br-lan' link is up
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'lan' has link connectivity
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'lan' is setting up now
Mon May 31 11:34:55 2021 daemon.notice netifd: Bridge 'br-lan' link is down
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'lan' has link connectivity loss
Mon May 31 11:34:55 2021 daemon.notice netifd: Network device 'lo' link is up
Mon May 31 11:34:55 2021 daemon.notice netifd: Interface 'loopback' has link connectivity
Mon May 31 11:34:55 2021 user.crit mountd[1303]: Starting OpenWrt (auto)mountd V1
Mon May 31 11:34:55 2021 daemon.notice netifd: lan (1314): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Mon May 31 11:34:55 2021 daemon.notice netifd: lan (1314): udhcpc (v1.22.1) started
Mon May 31 11:34:55 2021 user.crit mountd[1303]: trying to mount /tmp/run/mountd/ as the autofs root
Mon May 31 11:34:55 2021 kern.info kernel: [ 30.290000] br-lan: port 2(eth1) entered disabled state
Mon May 31 11:34:56 2021 daemon.notice netifd: lan (1314): Sending discover...
Mon May 31 11:34:56 2021 daemon.notice netifd: lan (1314): Performing a DHCP renew
Mon May 31 11:34:56 2021 user.emerg syslog: setting up led wlan
Mon May 31 11:34:56 2021 user.emerg syslog: setting up led eth0
Mon May 31 11:34:56 2021 user.emerg syslog: setting up led eth1
Mon May 31 11:34:56 2021 user.emerg syslog: - init complete -
Mon May 31 11:34:57 2021 daemon.notice netifd: Bridge 'br-lan' link is down
Mon May 31 11:34:57 2021 daemon.notice netifd: Interface 'lan' has link connectivity loss
Mon May 31 11:34:57 2021 daemon.info dnsmasq[1402]: started, version 2.71 cachesize 150
Mon May 31 11:34:57 2021 daemon.info dnsmasq[1402]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Mon May 31 11:34:57 2021 daemon.info dnsmasq[1402]: using local addresses only for domain box
Mon May 31 11:34:57 2021 daemon.warn dnsmasq[1402]: no servers found in /tmp/resolv.conf.auto, will retry
Mon May 31 11:34:57 2021 daemon.info dnsmasq[1402]: read /etc/hosts - 1 addresses
Mon May 31 11:34:57 2021 user.notice bomebox: hotplug.iface: action=ifup intf=loopback dev=lo
Mon May 31 11:34:59 2021 daemon.notice netifd: lan (1314): Sending discover...
Mon May 31 11:35:00 2021 daemon.info avahi-autoipd(br-lan)[1281]: Callout BIND, address 169.254.8.243 on interface br-lan
Mon May 31 11:35:00 2021 daemon.info avahi-daemon[1261]: Joining mDNS multicast group on interface br-lan.IPv4 with address 169.254.8.243.
Mon May 31 11:35:00 2021 daemon.info avahi-daemon[1261]: New relevant interface br-lan.IPv4 for mDNS.
Mon May 31 11:35:00 2021 daemon.info avahi-daemon[1261]: Registering new address record for 169.254.8.243 on br-lan.IPv4.
Mon May 31 11:35:04 2021 daemon.info avahi-autoipd(br-lan)[1281]: Successfully claimed IP address 169.254.8.243
Mon May 31 11:36:11 2021 user.notice bomebox: wifitoggle: enabling wifi
Mon May 31 11:36:11 2021 user.notice root: wifi button up
Mon May 31 11:36:12 2021 user.notice bomebox: hotplug.net: action=remove intf=wlan0 dev=
Mon May 31 11:36:12 2021 user.notice bomebox: WiFi LED OFF
Mon May 31 11:36:12 2021 user.notice bomebox: hotplug.net: action=add intf=wlan0 dev=
Mon May 31 11:36:12 2021 user.notice bomebox: WiFi LED BLINK
Mon May 31 11:36:23 2021 user.notice bomebox: hotplug.net: action=remove intf=wlan0 dev=
Mon May 31 11:36:23 2021 user.notice bomebox: WiFi LED OFF
Mon May 31 11:36:23 2021 user.notice bomebox: hotplug.net: action=add intf=wlan0 dev=
Mon May 31 11:36:23 2021 user.notice bomebox: WiFi LED ON
Mon May 31 11:36:24 2021 daemon.notice netifd: Network device 'wlan0' link is up
Mon May 31 11:36:24 2021 daemon.notice netifd: Interface 'wifi' is enabled
Mon May 31 11:36:24 2021 daemon.notice netifd: Interface 'wifi' is setting up now
Mon May 31 11:36:24 2021 daemon.info avahi-daemon[1261]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.153.1.
Mon May 31 11:36:24 2021 daemon.info avahi-daemon[1261]: New relevant interface wlan0.IPv4 for mDNS.
Mon May 31 11:36:24 2021 daemon.info avahi-daemon[1261]: Registering new address record for 192.168.153.1 on wlan0.IPv4.
Mon May 31 11:36:24 2021 daemon.notice netifd: Interface 'wifi' is now up
Mon May 31 11:36:24 2021 daemon.notice netifd: Interface 'wifi' has link connectivity
Mon May 31 11:36:24 2021 daemon.info hostapd: wlan0: STA f8:ff:c2:4b:e3:f7 IEEE 802.11: authenticated
Mon May 31 11:36:24 2021 daemon.info hostapd: wlan0: STA f8:ff:c2:4b:e3:f7 IEEE 802.11: associated (aid 1)
Mon May 31 11:36:24 2021 daemon.info dnsmasq[1402]: exiting on receipt of SIGTERM
Mon May 31 11:36:28 2021 daemon.info dnsmasq[1771]: started, version 2.71 cachesize 150
Mon May 31 11:36:28 2021 daemon.info dnsmasq[1771]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC
Mon May 31 11:36:28 2021 daemon.info dnsmasq-dhcp[1771]: DHCP, IP range 192.168.153.100 -- 192.168.153.249, lease time 12h
Mon May 31 11:36:28 2021 daemon.info dnsmasq[1771]: using local addresses only for domain box
Mon May 31 11:36:28 2021 daemon.warn dnsmasq[1771]: no servers found in /tmp/resolv.conf.auto, will retry
Mon May 31 11:36:28 2021 daemon.info dnsmasq[1771]: read /etc/hosts - 1 addresses
Mon May 31 11:36:28 2021 daemon.info dnsmasq[1771]: read /tmp/hosts/dhcp - 0 addresses
Mon May 31 11:36:28 2021 daemon.info dnsmasq-dhcp[1771]: read /etc/ethers - 0 addresses
Mon May 31 11:36:28 2021 user.notice bomebox: hotplug.iface: action=ifup intf=wifi dev=wlan0
Mon May 31 11:36:28 2021 user.notice bomebox: WiFi LED ON
Mon May 31 11:36:31 2021 daemon.info dnsmasq-dhcp[1771]: DHCPDISCOVER(wlan0) f8:ff:c2:4b:e3:f7
Mon May 31 11:36:31 2021 daemon.info dnsmasq-dhcp[1771]: DHCPOFFER(wlan0) 192.168.153.103 f8:ff:c2:4b:e3:f7
Mon May 31 11:36:32 2021 daemon.info dnsmasq-dhcp[1771]: DHCPREQUEST(wlan0) 192.168.153.103 f8:ff:c2:4b:e3:f7
Mon May 31 11:36:32 2021 daemon.info dnsmasq-dhcp[1771]: DHCPACK(wlan0) 192.168.153.103 f8:ff:c2:4b:e3:f7 MacBook-Pro
Hi, after logging into the web config and seeing the main screen, simply click on the menu button, and select Log
to get to the BomeBox Log.
BomeBox log
843 MT Player Headless on BomeBox started.
847 MT Player Headless start.
1163 load settings OK: last modified=1970-01-01 00:00:14 filesize=70 filename:/etc/mt/playerheadless.bmts
1169 NetDirectory added type #1 local identity "BomeBox - Net" at port 37000
1970-01-01 00:00:15: save settings OK: last modified=1970-01-01 00:00:15 filesize=70 filename:/etc/mt/playerheadless.bmts
1221 NetDirectory transmitted QBMNP_MT_PortShutdown to 0 broadcast and 0 unicast domains
2184 NetDirectory removed type #1 local port "BomeBox - Net"
3180 MIDIManager stopped.
3181 MIDIManager started.
2021-05-31 11:36:38: save settings OK: last modified=2021-05-31 11:36:38 filesize=70 filename:/etc/mt/playerheadless.bmts
Hi Michael,
this is a very strange error! Thank you for providing all this information.
At this point, I think it’s a hardware issue of some sort. We will repair it for you or send a new one to you. I’ll contact you in private for your options.
Sorry for that!
