Bome Crashing every time I use it if OMX-27 plugged in
If I have the OMX-27 plugged in, and try and open that port in Midi Translator Pro it just crashes
any idea why ?
Oh no, this is not good. We have not seen this before. Are you on Windows or Mac? What version? Do any other MIDI applications crash when the port is open? Are you connected with USB or MIDI?
What version of Bome MIDI Translator Pro are you using?
Could you share your Bome MIDI Translator Pro project file? Does it crash when using any project or just a particular one?
See this posting for instructions on sending a crash dump.
Hey Steve,
Thanks for such a quick response
It’s a brand new project
I’m on OSX 10.14.6
Attached Crash dump (as zip… sorry couldn’t seem to attach in raw format)
Archive.zip (91.5 KB)
I was connected via USB
The latest version is build 1064. Please try that.
sorted !! thank you … sorry I read 1.9.1 and assumed i was on latest… didn’t check build number doh !!
Easy Fix Steve !!! Thanks very much
Was the first time Bome had ever crashed (I have owned it since 2008) and resolved in under an hour
Brilliant :slight_smile:
