I use Bome with my Emeo and SWAM. It almost also freezes. I have to do to my task manager and shut it down. Is there a fix for this?
I assume by Bome you mean Bome MIDI Translator Pro? Maybe Bome Network Pro?
Are you on Windows or Mac? What version are you running. If MT Pro, do you have a project file we can look at? Are you using the trial version or paid version?
I’m not familiar with either EMEO or SAM, could you send me links to what they are?
Hey Steve,
Sorry. I should have been more specific.
I am using Bome Midi Translator Pro… paid version
emeo- is a digital saxophone.
Swam is the midi sound program that the Emeo uses.
I use the digital saxophone as a game controller and it works great it is just that the program freezes.
Here are the links-
Swam-
Emeo
These are my computer specs…
Thank you for any help you can give.
Brian
DESTINY.bmtp (5.2 KB)
Here is the file I am using
You may try to capture a crash dump by following these instructions.
I noticed that you are both sending and receiving MIDI from your Arduino as well as sending keystrokes to your operating system. Does the Arduino echo back the MIDI messages sent? Maybe there is a MIDI loop somewhere?
Is the source of you saxophone MIDI your Arduino WiFi and Bome MIDI Translator Pro connected to SWAM via Bome MIDI Translator 1?
I assume the keystrokes are for you game. If you disable your preset (so that only MIDI thru paths are in play), does it still crash?
