Hello there, I am having some issues with Bome. I am using it with a Ableton Novation Launchpad. My set up - I press a key on the launchpad, it outputs as keystrokes (So I press a key, and it outputs Control + Shift + A).
The keystrokes only work when I have clicked on OBS in the main streaming window. If I open any program but obs, in order to get key strokes working again, I must click Bome to maximize it, then open OBS and click the main window. Only then will my midi to hotkeys work.
It’s weird though. I can toggle things by pressing a hotkey on my keyboard (for example, A), but not by using the midi to hotkey. So if I type A in the OBS text box, the toggle will happen. If I use Bomes Midi to output A into the text box, even though A is outputted in textboxt, OBS doesnt register the A output and nothing happens.
I have another program, called LioranBoard which can not recieve any of Bomes hotkey outputs, and when it does it is very random. I switched from complicated ones like Control + Shift + X to just A, and it does not register, with or without that program open.
It seems that bomes only works on specific programs, and that the those programs must be open. Normally I can hotkey anywhere on any program to affect OBS, but with Bomes, OBS must be open for it to work. Even then, if I am clicked on chatbox (anything but main video, it will not work)
Am I missing something?
-Kevin
