I am seeing a weird thing where Bome Midi Translator is seeing midi notes offset by an octave compared to midi monitor and ableton. So what the others see as a A#2 BMTP sees as A#3 etc. how is this possible?
Hi, there is no note naming standard in MIDI so what some vendors might call note A#3 A#2.
If you want to use note names then you can define the note naming in Bome MIDI Translator Pro in the settings menu to define what note name middle C is. Personally that is why I try to stick with note numbers instead.
Thanx, should do the trick ![]()
Note numbers do not correspond either. Bome call it Note 58, midi monitor Note 46.
First I’ve heard of this. However I have heard some people getting confused of seeing hex instead of decimal. For instance 58 hex is 88 decimal.
