This pertains to Bome Network (without Bomebox). I have both Wifi and Ethernet connected and need both for my two computers.
Is it possible to force the Bome Network to only communicate by the ethernet ports? The jitter is pretty bad and I’m making an assumption here that it’s because Wifi is being grabbed.
In the Bome Network tool in settings. There is a place where you can exclude networks. You should be able to add your WiFi Network there and it will only use ethernet.
Thanks Steve with your advice I seem to be getting there. I’ve excluded the WIFI network and this is proven because I can’t see the Mac from the PC side now. I can however see the PC from the Mac.
To solve seeing the Mac from the PC I’ve added a firewall inbound rule with the current ethernet IP. Did not solve it.
