I have two Macbook Pros connected with Bome Network. Mac 1 passes midi signal to Mac 2 ok. I have three programs, Waves Superrack, Lightkey and Bome Midi Pro running on Mac2. All three programs have their midi input set up to receive from Bome Network Mac1. However, only the Waves program reacts to the incoming midi signals. Lightkey and Bome Midi Pro do not see the incoming signals even though their inputs are set up to do so. Any help?
Hi and welcome back!
What version of Bome Network are you running? Please make sure you are running 1.4.2. Also can you show me screen shots of the connection status from within the Bome Network tool on both machines? Are you using any Bome Network Remote MIDI Direct ports? I don’t have Waves, or LIghtkey, but I can see on MT Pro, MIDI Monitor and MIDI Tools simultaneously.
Thank you for your reply. I will get the info you need and get back to you by Wednesday.
Hello Steve,
I am happy to report that upon further investigation I found that it was the input sections of my apps that were the trouble and not the Bome Network. It now seems to be working just fine. Thank you very much for reaching out to help me. I am a big fan of Translator Pro and now Bome Network.
Thanks very much.
Randy Getsla
Thanks for letting us know!
