Bome overwhelmed (turning red in event monitor)
Hiya
I just finished my setup in bome and it gets overwhelmed (soundcut in DAWS + sign turning red in event monitor)
What would you recommend as I dont really wanna start it all over...
/e a lot of preset get activated on the same time, I tried delay some of them but still turning red
Hi, can you post your project file so I can take a look?
Any status here?  Looking for your project file so I can help you.
MIDI Translator Pro is optimized to use as little CPU as possible. It can execute many thousands of translators per second. However, it is possible that your project is generating tight loops (using timers, rules, or MIDI loops), which can drive CPU usage up quite a lot. That’s why Steve asked for your project file to inspect it for such possible causes of high CPU usage.
