Newbie here so forgive me if this has been previously covered but I searched and could not find…
When using the Bomebox as a router, what is the WiFi range/distance limit?
Hi, and welcome to the Bome community!
The BomeBox is with in the 2.4g industry standard. As with all WiFi products, the range will vary depending on your environment. We us a plastic case so that minimum restrictions are applied to the WiFI transceiver within the BomeBox.
You can read more about WiFi ranges in this (and probably many more) arcticles.
Thanks for the quick reply!
