BomeBox not showing midi ports after firmware update to 1.6
I just updated BMT and BomeBox to the newly released versions. (Thanks for the updates!)
BMT update went smoothly, but BomeBox doesn’t show any midi ports or routes after the firmware update.
I tried updating twice and rebooting, but as that didn’t help, I went back to 1.5.4, and immediately the midi ports and routes lists came back…
Clear your browser cache images and it should look fine. I actually put an extension on my Chrome browser Called “Clear Cache and Cookies” which allows you to selectively clear various components by web site. It was in the Chrome store.
Alternatively, you can use Private Mode which doesn’t use cache.
Ah yes, that was it. Thank you!
I’m glad it wasn’t a real bug. :blush:
This also got me. Perhaps it should be added to the v1.6 update process notes.
I’ll see if we can add that to the BomeBox instructions. Really nothing changed on the BomeBox regarding caching since the last release. This is pretty much a browser policy behavior.
We’ve just released BomeBox firmware 1.6.1, which should fix the issue you’ve reported here.
https://www.bome.com/products/bomebox#downloads
We will send out the announcement via newsletter in the next days.
