Since yesterday I’m having a serious issue with my BomeBox out of nowhere.
The Box worked fine but after a pause of playing for a couple of minutes it lagged by almost a second. Then suddenly it catched up with the notes played and worked as normal until it lagged again. Today the same thing. It does not help turning the box off and on. Sometimes single notes are lagging, sometimes not. Chords are always lagging. It’s changing all the time.
I could verify that no other hardware is involved. Moreover, when I bypass the BomeBox and access the sound box directly from the MIDI controller there are no lags.
I didn’t change any of my active presets, and I even deactivated all of them in the MIDI Translator, but nothing changed.
in which you remind me of the “My Bitstream” alias. In fact, I don’t use it anymore since a long time but it was still connected to the BomeBox by USB and now suddently caused the problem, meaning when I disconnect it the lagging is gone. I don’t even have it anymore in my (rather complex) diagram and that’s because I completely forgot about it, but I still left it connected “for probable future use”. Not a good idea.
So cause no. 3 is likely valid. The old Bitstream is a MIDI monster and can do very nasty things.
