Hi, we have no updates on progress.
Below are my personal comments and not representing Bome.
I have been monitoring these requests for some time now and am curious as to the specific vision of the users that have been requesting OSC capabilities and issues that are trying to be resolved. I ask this primarily because OSC is now becoming more common with DAWs which of course usually run on a host operating system and there are some tools available on computers to handle OSC messages already.
I’m curious if this request is primarily to be able to attach a MIDI controller to BomeBox and have it convert MIDI to OSC and OSC to MIDI or for some other reason.
Of course MIDI 1.0 resolution is 7 or 14 bit and OSC is 32 bit so there would likely be some resolution lost in the conversion. Also the nature of of OSC is pretty free form so there are no ‘standard’ OSC messages. Most vendors have their own implementation and users can even define their own OSC message types (within the OSC framework).
I would be interested in understanding more from a user perspective their expected use case so that whenever OSC is implemented on BomeBox, the implementation has a chance of meeting the majority of use cases. I’m also interested because in some cases, I believe there may be other solutions other than putting OSC on BomeBox. If you using one of these other solutions and would like to offload to BomeBox some OSC functionality, I will like to understand that as well.
Also as MIDI 2.0 development continues (which has higher resolution and maybe higher than OSC), I’m interested to understand if any future use cases for MIDI 2.0 conversion to and from OSC would be necessary.
Again, this is not Bome Corporation speaking. Just a curious support guy who have watched this OSC requests come in and have not seen any real world examples of given use cases that could not be solved by other means.
A few OSC tools available that I have played with are listed below. For MIDI to OSC conversion and visa versa, I usually use one of these and the application is usually a host that is running a DAW of some sorts. I have not run into a use case yet that requires an OSC hardware controller to convert to MIDI without the need of a host. (Maybe I am running a sheltered life).
Mac - OSCulator
Windows - OSCII-bot, Central Control Pro, Pd (Pure data)
P.S. I continue to ensure these requests are passed along for consideration.
