I have 3 M-vave Chocolate connected to Bomebox USB host via powered hub.
Only 2 are working at one time.
Deactivating one working connection another can be activated.
What can I do?
Ruediger
What can I do?
Ruediger
Sorry about your issue. It is possible that your controllers are not USB class compliant. To test this, you can hook them up to a Windows or Mac computer (without an special drivers loaded) and see if you have the same issue.
Also, once your controllers are hooked up to BomeBox, you can go to the Log page of your BomeBox to see if your controllers are recognized there. For instance, when plugging in my MIDIHub, I see this message:
814885266: Discovered MIDI INPUT : Midihub MH-3GJ90TN [1],Midihub MH-3GJ90TN [2],Midihub MH-3GJ90TN [3],Midihub MH-3GJ90TN [4]
814885266: Discovered MIDI OUTPUT: Midihub MH-3GJ90TN [1],Midihub MH-3GJ90TN [2],Midihub MH-3GJ90TN [3],Midihub MH-3GJ90TN [4]
Hello,
here is the log:
33581: NetDirectory: adding new broadcast domain: 192.168.153.255 (netmask:255.255.255.0)
61565: NetDirectory added type #1 remote port ‘DESKTOP-5FT75F4’ at address 192.168.153.154:37000
61928: TCP_MIDI_Server: client connecting…
61929: Incoming ClientConnection (192.168.153.154:60758) has been instantiated.
61931: ClientConnection started.
61933: Client ‘DESKTOP-5FT75F4’ is connecting…
61934: NetMIDI server: incoming connection request from client “DESKTOP-5FT75F4”.
61935: NetMIDI server: auto-accepting incoming connection from “DESKTOP-5FT75F4” because it was connected before (currentlyAutoAcceptClients)
61935: NetMIDI server: accepting client: DESKTOP-5FT75F4 (192.168.153.154:60758)
61936: NetMIDI Server: accepting session with “DESKTOP-5FT75F4”.
61936: [ClientConnection 1]: established session with client “DESKTOP-5FT75F4”. Remote caps=25
61936: Client ‘DESKTOP-5FT75F4’ has MIDI connected.
61937: NetMIDI server: connection authenticated with remote client “DESKTOP-5FT75F4” (192.168.153.154:60758)
61953: Discovered MIDI INPUT : DESKTOP-5FT75F4
61953: Discovered MIDI OUTPUT: DESKTOP-5FT75F4
61959: Connected to “DESKTOP-5FT75F4” (“DESKTOP-5FT75F4” at 192.168.153.154:60758).
152809: MIDI INPUT “SINCO” now successfully opened.
152809: Opened MIDI INPUT “SINCO”
152809: Discovered MIDI INPUT : SINCO
152809: Discovered MIDI OUTPUT: SINCO
185826: MIDI INPUT “SINCO (2)” now successfully opened.
185826: Opened MIDI INPUT “SINCO (2)”
185826: Discovered MIDI INPUT : SINCO (2)
185827: Discovered MIDI OUTPUT: SINCO (2)
233952: Discovered MIDI INPUT : SINCO (3)
233952: Discovered MIDI OUTPUT: SINCO (3)
233957: Opened MIDI INPUT “SINCO (2)”
At the end you can see the 3rd device is discovered, but opened is the 2nd.
What this mean?
Best regards
Ruediger
The log shows all 3 discovered so maybe you don’t have he right MIDI routing.
Could you take a snapshot of:
I suspect there is either a routing that is not set up or if you are running a project file, it may not be set up correctly to process all 3 devices.
Hello,
how can I send you a file (screenshots)?
Best regards
Ruediger
Open your browser and use the screenshot function of your computer to take them. Then paste them into your posting.
It appears that your project file is controlling the routing/processing of MIDI messages. Could you share that please? My guess is that you need to change routing or port alias assignments in your project file and then upload it with the changes. I should be able to advise further when seeing your project file. All 3 devices are being seen by BomeBox as indicated in your first screenshot.
Hello,
you are right. it was the routing in the project file.
Thank you, everything is fine.
Best regards
Ruediger
I’m glad you figured it out!
