Bomes 1.9.0 hangs on exit
Running on High Sierra 10.13.6.
Bomes does not shut down correctly. Hangs and requires a [FORCE QUIT] to close.
Anyone else experiencing this?
I have not, however I’m on Big Sur. A few possibilities.
  1. Does it always hang on the same project file? Perhaps there is a race condition within the project file itself. I’m happy to look at it if you want to either post it or email it if you don’t want to publicly share it.
  2. Check you accessibility permissions. Perhaps it is trying to save the settings and accessibiility is not allowing it?
  3. Try uninstalling and re-installing Bome MIDI Translator Pro.
If these don’t work, then get back to us and maybe we can can try some other troubleshooting techniques.
I’ll keep tabs on it Steve. Literally since posting this it has started to behave. So it could just require a fresh OS.
Cheers.
Here is a posting with more troublshooting tips if it happens again.
Crash Freeze or Hang
Updated OS and all is well.
Thanks.
Oh great to hear! Thanks for letting us know.
One thing Florian,
The sign tool is not working on said upgraded OS.
I’ve installed Big Sur.
Sorry for that! For MT Player licensees, we have a new version of the Bome SignTool that works on Big Sur.
