I've got an APC mini going through Bome to Ma2 OnPC 3.8.0.0. I've got temp buttons that work as expected when clicked - flash intensities to full, then release when the press is released. However when I trigger through my APC, the temp button stays on. Bome is registering both a "Note On" and "Note Off." Any ideas? Bome file attached.
Yes, the APC-MINI sends note-off velocity at 127 (7F Hex) which confuses many applications (and even itself if you want to LED feedback) . You should be able to translate the note-off message as
Incoming:Note-Off MIDI Channel 1 set note to pp any velocity
Ah, I see. Could you point me in the right direction to start learning about LED feedback/utilizing the LEDs? Not really finding anything helpful with a google search.
