Can I use a Midi signal to trigger holding a keystroke with a different Midi signal?
I’m using edrums and translating that Midi signal into keyboard strokes - for instance snare is A, crash is B. Can I set up Translator so that when I hold my foot down on a pedal, the next keystroke would be held down until I lift my foot from the pedal (AAAAAAAAAAA instead of just A)?
Yes, on the outgoing action would be key down and you could turn on key repeat as an option. The incoming trigger would be a note-on. Then a separate incoming trigger would be a note-off and would have an outgoing action of keystroke up.
See the attached project file.
MIDI-to-Key.bmtp (1.6 KB)
