CC fader value to tricky Sysex question
I am trying to set up a translator to send fader CC value of 0-127 and output a sysex message (hex). However, the sysex message is a little tricky.
F0 43 14 3E 10 00 00 00 00 00 01 5F F7 = -40db
F0 43 14 3E 10 00 00 00 00 00 01 5A F7 = -41db
F0 43 14 3E 10 00 00 00 00 00 01 55 F7 = -42db
As you can see if the fader goes up or down by 1db, the second to last bit increments /decrements by a certain amount. This amount does not matter to me.
After it reaches ‘01 00’ or ‘01 7F’ the “01” adjacent bit increases or decreases by 1.
ie
F0 43 14 3E 10 00 00 00 00 00 01 7F F7
F0 43 14 3E 10 00 00 00 00 00 02 00 F7
I want to make it so that every time I increment CC fader value by 1, it inc/dec by 16 (dec) in the sysex message.
How would I make this work?
From the SysEX message, it looks like it is creating a 14 bit value with both MSB and LSB representing 7 bits.
The following example multiplies the input value by 16. Then we split the result off into 2 7 bit values for the SysEX message where we use tt for MSB and uu for LSB
Here are the rules.
ga=qq*16
Log "Log Input qq Output is %ga%"
// Get MSB into tt
tt=ga>>7
// Get LSB into uu
uu=ga&127
Log "Log MSB=0x%02x tt% LSB=0x%02x uu%"
And an excerpt of what the log shows
1: 0.0:2 Log Input qq Output is 144
2: 0.0:7 Log MSB=0x01 LSB=0x10
3: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 10 F7
4: 0.0:2 Log Input qq Output is 160
5: 0.0:7 Log MSB=0x01 LSB=0x20
6: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 20 F7
7: 0.0:2 Log Input qq Output is 176
8: 0.0:7 Log MSB=0x01 LSB=0x30
9: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 30 F7
10: 0.0:2 Log Input qq Output is 192
11: 0.0:7 Log MSB=0x01 LSB=0x40
12: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 40 F7
13: 0.0:2 Log Input qq Output is 208
14: 0.0:7 Log MSB=0x01 LSB=0x50
15: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 50 F7
16: 0.0:2 Log Input qq Output is 224
17: 0.0:7 Log MSB=0x01 LSB=0x60
18: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 01 60 F7
19: 0.0:2 Log Input qq Output is 256
20: 0.0:7 Log MSB=0x02 LSB=0x00
21: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 02 00 F7
22: 0.0:2 Log Input qq Output is 288
23: 0.0:7 Log MSB=0x02 LSB=0x20
24: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 02 20 F7
25: 0.0:2 Log Input qq Output is 336
26: 0.0:7 Log MSB=0x02 LSB=0x50
27: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 02 50 F7
28: 0.0:2 Log Input qq Output is 384
29: 0.0:7 Log MSB=0x03 LSB=0x00
30: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 03 00 F7
31: 0.0:2 Log Input qq Output is 448
32: 0.0:7 Log MSB=0x03 LSB=0x40
33: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 03 40 F7
34: 0.0:2 Log Input qq Output is 496
35: 0.0:7 Log MSB=0x03 LSB=0x70
36: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 03 70 F7
37: 0.0:2 Log Input qq Output is 560
38: 0.0:7 Log MSB=0x04 LSB=0x30
39: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 04 30 F7
40: 0.0:2 Log Input qq Output is 608
41: 0.0:7 Log MSB=0x04 LSB=0x60
42: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 04 60 F7
43: 0.0:2 Log Input qq Output is 656
44: 0.0:7 Log MSB=0x05 LSB=0x10
45: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 05 10 F7
46: 0.0:2 Log Input qq Output is 672
47: 0.0:7 Log MSB=0x05 LSB=0x20
48: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 05 20 F7
49: 0.0:2 Log Input qq Output is 704
50: 0.0:7 Log MSB=0x05 LSB=0x40
51: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 05 40 F7
52: 0.0:2 Log Input qq Output is 768
53: 0.0:7 Log MSB=0x06 LSB=0x00
54: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 06 00 F7
55: 0.0:2 Log Input qq Output is 848
56: 0.0:7 Log MSB=0x06 LSB=0x50
57: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 06 50 F7
58: 0.0:2 Log Input qq Output is 912
59: 0.0:7 Log MSB=0x07 LSB=0x10
60: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 07 10 F7
61: 0.0:2 Log Input qq Output is 992
62: 0.0:7 Log MSB=0x07 LSB=0x60
63: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 07 60 F7
64: 0.0:2 Log Input qq Output is 1008
65: 0.0:7 Log MSB=0x07 LSB=0x70
66: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 07 70 F7
67: 0.0:2 Log Input qq Output is 1024
68: 0.0:7 Log MSB=0x08 LSB=0x00
69: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 08 00 F7
70: 0.0:2 Log Input qq Output is 1072
71: 0.0:7 Log MSB=0x08 LSB=0x30
72: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 08 30 F7
73: 0.0:2 Log Input qq Output is 1136
74: 0.0:7 Log MSB=0x08 LSB=0x70
75: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 08 70 F7
76: 0.0:2 Log Input qq Output is 1168
77: 0.0:7 Log MSB=0x09 LSB=0x10
78: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 09 10 F7
79: 0.0:2 Log Input qq Output is 1216
80: 0.0:7 Log MSB=0x09 LSB=0x40
81: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 09 40 F7
82: 0.0:2 Log Input qq Output is 1264
83: 0.0:7 Log MSB=0x09 LSB=0x70
84: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 09 70 F7
85: 0.0:2 Log Input qq Output is 1328
86: 0.0:7 Log MSB=0x0a LSB=0x30
87: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0A 30 F7
88: 0.0:2 Log Input qq Output is 1376
89: 0.0:7 Log MSB=0x0a LSB=0x60
90: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0A 60 F7
91: 0.0:2 Log Input qq Output is 1440
92: 0.0:7 Log MSB=0x0b LSB=0x20
93: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0B 20 F7
94: 0.0:2 Log Input qq Output is 1488
95: 0.0:7 Log MSB=0x0b LSB=0x50
96: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0B 50 F7
97: 0.0:2 Log Input qq Output is 1552
98: 0.0:7 Log MSB=0x0c LSB=0x10
99: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0C 10 F7
100: 0.0:2 Log Input qq Output is 1600
101: 0.0:7 Log MSB=0x0c LSB=0x40
102: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0C 40 F7
103: 0.0:2 Log Input qq Output is 1664
104: 0.0:7 Log MSB=0x0d LSB=0x00
105: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0D 00 F7
106: 0.0:2 Log Input qq Output is 1712
107: 0.0:7 Log MSB=0x0d LSB=0x30
108: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0D 30 F7
109: 0.0:2 Log Input qq Output is 1776
110: 0.0:7 Log MSB=0x0d LSB=0x70
111: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0D 70 F7
112: 0.0:2 Log Input qq Output is 1792
113: 0.0:7 Log MSB=0x0e LSB=0x00
114: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0E 00 F7
115: 0.0:2 Log Input qq Output is 1824
116: 0.0:7 Log MSB=0x0e LSB=0x20
117: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0E 20 F7
118: 0.0:2 Log Input qq Output is 1856
119: 0.0:7 Log MSB=0x0e LSB=0x40
120: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0E 40 F7
121: 0.0:2 Log Input qq Output is 1920
122: 0.0:7 Log MSB=0x0f LSB=0x00
123: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0F 00 F7
124: 0.0:2 Log Input qq Output is 1968
125: 0.0:7 Log MSB=0x0f LSB=0x30
126: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0F 30 F7
127: 0.0:2 Log Input qq Output is 2032
128: 0.0:7 Log MSB=0x0f LSB=0x70
129: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: F0 43 14 3E 10 00 00 00 00 00 0F 70 F7
And here is the project file.
CC-to-SysEX-times16.bmtp (1.1 KB)
That did it!
Will def look into your solution and learn from it- it’s very helpful to know!
Thanks again Steve.
