I am trying to creat a file that to take the CC from a Line 6 FBV3 and change it to Notes to Map to Ableton Live. I think i have watched enough videos to understand the writing of the Translators. MY confusion is how do I route that? I have tried FBV 3to FBV 3, BOme 1 tro FVB3 and the reverse and several other combos. Am I missing something with the MID Router?
1) click on project level so you can see assigned input and output ports
2) Create meaning full alias names
3) Check the boxes for the aliases you want Line 6 FB3 In from your controler and Ableton Live (Bome MIDI Translator Virtual port 1 BMT 1) to send to Live
In Abelton Live MIDI Preferences assuming you want this to control functions Click BMT 1 for input to match what you did in step 3 above.
Then use MIDI Learn in Ableton Live to assign what you want to do.
Also I noticed that on your first transator you were sending value pp as output. Since pp is a local variable, by definition the value is unknown unless you assign it. I assume you really want output of 127 so I set it in the attached.
Sorry didnt get a chance to fully test it out until today. There were some settings in Ableton Prefernces I had to experiement with also in regards to the FBV 3. The Bome settings in Ableton are the same as the IAC settings so I will remember that. I think I actually like the the stock devices instead of the Aliases. It's a nice touch, but I guess I am just use to Abelton. My instincts were right in my settings in Bome, but the setttings in Ableton didmt jive.
I ended up deleting the pedal pass through off CC it just complicated things and was very choppy. Extra step in processing that wasn't required I suppose. Thanks again for your help!
