thanks for your quick answer - just in the moment i saw, if i activate "incoming" and "outgoing" in my log window - there is no data coming to the window - only MIDI IN and MIDI Out show me some data - is it a problem of my preference settings? - in the attachement you can find my file - greetings wolle
Yes, in general for incoming MIDI messages if you see MINI IN but no Incoming, then you have your incoming trigger parameters set incorrectly. I could tell by looking at your log window.
dear steve - i changed my midi controller (from palette to arturia) and everything runs perfectly - so thank you again for your help - stay healthy ! best regards wolle
The only thing I see wrong is that the translator is unchecked which means it is disabled. Therefore no translators and everything goes through the default thru path untouched.
