Channel Aftertouch pressure to Midi CC Value
Hello Steve.
Is there a way to Translate a MIDI Aftertouch feedback to Midi CC value feedback?
I want to utilize the Mackie VU meter feedback be translated back to the Streamdeck’s 8 button span.
There is a MIDI Plugin developed by TrevLiga Spel to do Mackie and display VU Meter in the Streamdeck using the plugin . The plugin can also read Script but recognizes MIDI Note and MIDI CC only.
My use case is to make 8 buttons span display the VU Meter using my own Graphics.
Arbi
Yes, this can be done. Please find the attached project file. In this case I set my preset aliases as follows. You will want to adjust them to match that of your actual device and application.
Device selection is set at the preset level.
Aftertouch-to-CC-2023-07-08.bmtp (1.0 KB)
How can I isolate all other Mackie Messages and let only the Chanel Pressure aftertouch to be converted to MIDI CC value to pass through? so I can use it in my streamdeck.
For messages you want passed through untouched, create MIDI thru paths. Any message that doesn’t have a translator (with the swallow option set), will pass through untouched.
Below is an example of pass thru routes to aliases that I created.
