Condition Rekordbox PAD 1 (hotcue,PadFX1, Beatjump 1)
Change the outgoing action to Note 13 from note 112
You can use the same local variables that include.
oo,pp,qq,rr,ss,tt,uu,vv,ww,xx
Local variables are not and cannot be shared across translators (unless the two translators have the same incoming trigger.
I try to use locals whenever I can and that is when the values do not need to be shared.
For global variables, I usually document them and set them at project start. See this tutorial.
it still does not work. It’s even worse if I may say so.
The LED no longer works and my fader remains frozen (I remapped it in rekordbox)
I stick with your 1st idea
My translator is incorrectly configured, it must probably be missing one more line
I learned quite a bit thanks to you but that is completely beyond my knowledge.
Attached photos for maximum details
So if you want Note 13 with the current value to go to your application and the LED to note 70 to go to your controller, you need 2 translators. One for output of each is this what you want?
Looking back at your original post, I think this is what you want.
010 last fonctionelleTOUT (save avant modif ga gb)-sjc-a.bmtp (37.9 KB)
yes that’s what I want to do I’ll look tomorrow.
here in France it is late.
thank you very much for taking the time to help me
That works
Thank you very much, I’ve been trying to resolve this problem by myself for 3 days in vain.
Now I still have to configure 2 SHIFT buttons, I hope it’s less complicated than the LEDs.
I’m going to watch your tutorial on YouTube.
Hello Steve,
The shift button on the TOOGLE version (preset 7) works perfectly.
I have a problem with SHIFT HOLD (preset 8) in fact the toggle between QUANTIZE and SLIP works poorly.
Let me explain:
  • QUANTIZE works correctly since I don’t need to press SHIFT HOLD
  • I press SHIFT HOLD and SLIP it doesn’t work 1 time out of 3-4
1:9.0:4 QUANTIZE 1
2: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 51 7F
3: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 51 00
4:8.0:3 SHIFT ON
5:8.1:3 SHIFT OFF (I didn’t release)
6:9.0:4 QUANTIZE 1
7: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 51 7F
8: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: B0 1C 01
9: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 51 00
Problem Shift (for steve).bmtp (40.7 KB)
I would need a flashy LED (250 ms) for the shift button, when you have time to spare
LED is flashy when shift is activated
It stays on when shift is disabled
Thanks in advance
Do you have a list of global variables that you are using and what they are used for?
Hard to tell what is going on here because you didn’t document them in one place. See this tutorial.
I suspect you may be using global variable ā€˜gf’ somewhere else in your project and it is interfering with the new functionality you are adding.
I suspect you will want o make the incoming action of 8.1 Note Off with velocity 0 instead of any velocity.
For me it seems to work just fine. You might want to check incoming box on the log window to see what caused it to trigger.
I’ll look at my variables.
I keep you informed
THANKS
Hi Steve, I have something new regarding my problem with switching Quantize a Slip to the same button.
I opened a new project with the same settings.
I used another button (I used 3 different ones for my tests) to control the QUANTIZE or SLIP toggle.
It works. WEIRD
Is it possible that this button is faulty?
It works very well without Shift
Here is CAPTURE (Quantize button change - Slip) functional
1: MIDI IN [MixTrack Pro]: 90 48 7F
2:1.0:2 QUANTIZE
3: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 01 7F
4: MIDI IN [MixTrack Pro]: 90 48 00
5: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 48 00
6: MIDI IN [MixTrack Pro]: 90 4A 7F
7:2.0:3 shift on
8: MIDI OUT [MixTrack Pro]: 90 4A 7F
9: MIDI IN [MixTrack Pro]: 90 48 7F
10:1.1:2 SLIP
11: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 02 7F
12: MIDI IN [MixTrack Pro]: 90 48 00
13: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 48 00
14: MIDI IN [MixTrack Pro]: 90 4A 00
15:2.1:2 shift off
16: MIDI OUT [MixTrack Pro]: 90 4A 00
Capture Button causing problem (Quantize Toggle - Slip)
I’m not quite sure I understand what the problem is. Maybe you need to put a blocking translator for note of note 51 with outgoing action of none. It is possible that notes are slipping through the designated MIDI thru paths and feeding back to the controller causing strange behavior. I’m not seeing anything wrong in they way it is behaving here but again I don’t have your controller or application hooked up.
I put a blocking translator here for when you release the slip/quantize button. But if your buttons are toggles on your controller, you will only see messages when you press them.
I really don’t know how your slip/quantize button behaves? Is it a toggle or momentary?
Problem Shift (for steve)-2024-04-28.bmtp (41.6 KB)
It’s a toggle with shift.
No problem, I changed the button and it works.
I’m going to look in detail at my BMT mapping and try to put things in order.
