Connect Roland Boutique via USB
At the moment, it does not seem possible to connect Roland Boutique devices, such as the JU-06a and SE-02, via USB MIDI.
While these devices (as far as I know) are not class compliant, some other USB hosts recognize them. For instance, the AKAI Force is able to connect all of my Boutique synths via USB MIDI, with input/output working flawlessly.
Would this be possible on a future Bomebox version too?
Hi, I’m not aware of any effort write special USB drivers for non class-compliant devices. I suggest use MIDI DIN and a class compliant MIDI DIN to USB converter if you want to use USB.
Thanks. I’m just curious what AKAI is doing, and if there’s some simple shortcut. Google searches for AKAI and Roland Boutique do not show up anything, so it’s not even advertised as a feature. Makes me think that it is something really simple that they’re doing that makes the Boutiques work.
Actually, we believe that a future firmware update will include support for Roland Boutique devices (but we have not tested yet). Because this is part of a larger update (most likely firmware v2.0), it will still take some time.
Ruben, if you don’t mind, I’ll contact you when we have a beta firmware ready for noncommittal testing.
Please do, that would be great. Thanks so much!
