I tried the new version it seems it doenst send the keystrokes.
For taping button A from the iRig BlueBoard i get the log:
151585 - IN 0.11 On app activated: ‘Cubase13.exe’
151585 - RULE 0.11:1 assignment: (gc=1) = 1
151585 - 0.11:2 Log Cubase is Focused gc=1
154293 - MIDI IN [iRig Blueboard]: B0 14 7F
154293 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=20 with any value=127
154293 - RULE 0.5:3 assignment: (ga=pp) = 20
154293 - RULE 0.5:8 expression: (gb=gb+1) = 1
154293 - MIDI IN [iRig Blueboard]: B0 00 00
154293 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
154293 - RULE 0.5:3 assignment: (ga=pp) = 0
154293 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
154293 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
154392 - MIDI IN [iRig Blueboard]: B0 14 00
154392 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=20 with any value=0
154392 - RULE 0.5:3 assignment: (ga=pp) = 20
154392 - RULE 0.5:8 expression: (gb=gb+1) = 2
154392 - MIDI IN [iRig Blueboard]: B0 00 00
154392 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
154392 - RULE 0.5:3 assignment: (ga=pp) = 0
154392 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
154392 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
154642 - IN 0.6 On timer ‘TapCounter’
154642 - RULE 0.6:1 assignment: (pp=ga) = 0
154642 - RULE 0.6:2 assignment: (qq=gb) = 2
154642 - RULE 0.6:3 assignment: (gb=0) = 0
154642 - 0.6:5 Log TapCounter cc=0, tap count=2
154642 - RULE 0.6:7 Perform ‘Tap’, pp,qq
154642 - IN 0.7 Perform tap(0,2)
154642 - 0.7:1 Log Perform tap 0, 2
154642 - RULE 0.7:4 assignment: (rr=20) = 20
154642 - RULE 0.7:9 Perform ‘focus’,pp,qq,rr
154642 - RULE 0.7 exit rules, skip Outgoing Action
154642 - IN 0.8 Perform Focus(0,2,20)
154642 - RULE 0.8:2 Perform ‘Focus-check’,pp,qq,rr
154642 - RULE 0.8:3 condition satisfied: if gc==1 then exit rules, skip Outgoing Action
154642 - IN 0.9 Perform Focus-check(0,2,20)
154642 - 0.9:1 Log Focuscheck being performed
154892 - OUT 0.9 Perform ‘Getfocus’ with 3 parameters, delay:250 millisec
154892 - IN 0.10 Perform Getfocus(0,2,20)
154892 - RULE 0.10:1 assignment: (ss=gc) = 1
154892 - 0.10:2 Log Getfocus returned 1
154892 - RULE 0.10:17 assignment: (ga=0) = 0
154892 - RULE 0.10 exit rules, skip Outgoing Action
159133 - IN 0.12 On app deactivated: ‘Cubase13.exe’
159133 - RULE 0.12:1 assignment: (gc=0) = 0
159133 - 0.12:2 Log Cubase is Not Focused gc=0
Keystoke Numpad 1 is not pressed
For Button B of the Blueboard i get this:
241753 - IN 0.11 On app activated: ‘Cubase13.exe’
241753 - RULE 0.11:1 assignment: (gc=1) = 1
241753 - 0.11:2 Log Cubase is Focused gc=1
245661 - MIDI IN [iRig Blueboard]: B0 15 7F
245661 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=21 with any value=127
245661 - RULE 0.5:3 assignment: (ga=pp) = 21
245661 - RULE 0.5:8 expression: (gb=gb+1) = 1
245661 - MIDI IN [iRig Blueboard]: B0 00 00
245661 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
245661 - RULE 0.5:3 assignment: (ga=pp) = 0
245661 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
245661 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
245758 - MIDI IN [iRig Blueboard]: B0 15 00
245758 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=21 with any value=0
245758 - RULE 0.5:3 assignment: (ga=pp) = 21
245758 - RULE 0.5:8 expression: (gb=gb+1) = 2
245758 - MIDI IN [iRig Blueboard]: B0 00 00
245758 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
245758 - RULE 0.5:3 assignment: (ga=pp) = 0
245758 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
245758 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
246008 - IN 0.6 On timer ‘TapCounter’
246008 - RULE 0.6:1 assignment: (pp=ga) = 0
246008 - RULE 0.6:2 assignment: (qq=gb) = 2
246008 - RULE 0.6:3 assignment: (gb=0) = 0
246008 - 0.6:5 Log TapCounter cc=0, tap count=2
246008 - RULE 0.6:7 Perform ‘Tap’, pp,qq
246008 - IN 0.7 Perform tap(0,2)
246008 - 0.7:1 Log Perform tap 0, 2
246008 - RULE 0.7:4 assignment: (rr=20) = 20
246008 - RULE 0.7:9 Perform ‘focus’,pp,qq,rr
246008 - RULE 0.7 exit rules, skip Outgoing Action
246008 - IN 0.8 Perform Focus(0,2,20)
246008 - RULE 0.8:2 Perform ‘Focus-check’,pp,qq,rr
246008 - RULE 0.8:3 condition satisfied: if gc==1 then exit rules, skip Outgoing Action
246008 - IN 0.9 Perform Focus-check(0,2,20)
246008 - 0.9:1 Log Focuscheck being performed
246258 - OUT 0.9 Perform ‘Getfocus’ with 3 parameters, delay:250 millisec
246258 - IN 0.10 Perform Getfocus(0,2,20)
246258 - RULE 0.10:1 assignment: (ss=gc) = 1
246258 - 0.10:2 Log Getfocus returned 1
246258 - RULE 0.10:17 assignment: (ga=0) = 0
246258 - RULE 0.10 exit rules, skip Outgoing Action
251497 - IN 0.12 On app deactivated: ‘Cubase13.exe’
251497 - RULE 0.12:1 assignment: (gc=0) = 0
251497 - 0.12:2 Log Cubase is Not Focused gc=0
No Keystoke Numpad 2
For Button C of the Blueboard i get this
295998 - MIDI IN [iRig Blueboard]: B0 16 7F
295998 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=22 with any value=127
295998 - RULE 0.5:3 assignment: (ga=pp) = 22
295998 - RULE 0.5:8 expression: (gb=gb+1) = 1
295998 - MIDI IN [iRig Blueboard]: B0 00 00
295998 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
295998 - RULE 0.5:3 assignment: (ga=pp) = 0
295998 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
295998 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
296202 - MIDI IN [iRig Blueboard]: B0 16 00
296202 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=22 with any value=0
296202 - RULE 0.5:3 assignment: (ga=pp) = 22
296202 - RULE 0.5:8 expression: (gb=gb+1) = 2
296202 - MIDI IN [iRig Blueboard]: B0 00 00
296202 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
296202 - RULE 0.5:3 assignment: (ga=pp) = 0
296202 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
296202 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
296452 - IN 0.6 On timer ‘TapCounter’
296452 - RULE 0.6:1 assignment: (pp=ga) = 0
296452 - RULE 0.6:2 assignment: (qq=gb) = 2
296452 - RULE 0.6:3 assignment: (gb=0) = 0
296452 - 0.6:5 Log TapCounter cc=0, tap count=2
296452 - RULE 0.6:7 Perform ‘Tap’, pp,qq
296452 - IN 0.7 Perform tap(0,2)
296452 - 0.7:1 Log Perform tap 0, 2
296452 - RULE 0.7:4 assignment: (rr=20) = 20
296452 - RULE 0.7:9 Perform ‘focus’,pp,qq,rr
296452 - RULE 0.7 exit rules, skip Outgoing Action
296452 - IN 0.8 Perform Focus(0,2,20)
296452 - RULE 0.8:2 Perform ‘Focus-check’,pp,qq,rr
296452 - IN 0.9 Perform Focus-check(0,2,20)
296452 - 0.9:1 Log Focuscheck being performed
296462 - OUT 0.8 Activating app: ‘Cubase13.exe’
296539 - IN 0.11 On app activated: ‘Cubase13.exe’
296539 - RULE 0.11:1 assignment: (gc=1) = 1
296539 - 0.11:2 Log Cubase is Focused gc=1
296702 - OUT 0.9 Perform ‘Getfocus’ with 3 parameters, delay:250 millisec
296702 - IN 0.10 Perform Getfocus(0,2,20)
296702 - RULE 0.10:1 assignment: (ss=gc) = 1
296702 - 0.10:2 Log Getfocus returned 1
296702 - RULE 0.10:17 assignment: (ga=0) = 0
296702 - RULE 0.10 exit rules, skip Outgoing Action
298014 - IN 0.12 On app deactivated: ‘Cubase13.exe’
298014 - RULE 0.12:1 assignment: (gc=0) = 0
298014 - 0.12:2 Log Cubase is Not Focused gc=0
For pressing Button D:
332337 - MIDI IN [iRig Blueboard]: B0 17 7F
332337 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=23 with any value=127
332337 - RULE 0.5:3 assignment: (ga=pp) = 23
332337 - RULE 0.5:8 expression: (gb=gb+1) = 1
332337 - MIDI IN [iRig Blueboard]: B0 00 00
332337 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
332337 - RULE 0.5:3 assignment: (ga=pp) = 0
332337 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
332337 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
332441 - MIDI IN [iRig Blueboard]: B0 17 00
332441 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=23 with any value=0
332441 - RULE 0.5:3 assignment: (ga=pp) = 23
332441 - RULE 0.5:8 expression: (gb=gb+1) = 2
332441 - MIDI IN [iRig Blueboard]: B0 00 00
332441 - IN 0.5 Control Change on ch. 1 with any CC# set “pp” to CC#=0 with any value=0
332441 - RULE 0.5:3 assignment: (ga=pp) = 0
332441 - RULE 0.5:4 condition satisfied: if pp<20 then exit rules, skip Outgoing Action
332441 - OUT 0.5 One-shot timer ‘TapCounter’: 250 ms delay
332691 - IN 0.6 On timer ‘TapCounter’
332691 - RULE 0.6:1 assignment: (pp=ga) = 0
332691 - RULE 0.6:2 assignment: (qq=gb) = 2
332691 - RULE 0.6:3 assignment: (gb=0) = 0
332691 - 0.6:5 Log TapCounter cc=0, tap count=2
332691 - RULE 0.6:7 Perform ‘Tap’, pp,qq
332691 - IN 0.7 Perform tap(0,2)
332691 - 0.7:1 Log Perform tap 0, 2
332691 - RULE 0.7:4 assignment: (rr=20) = 20
332691 - RULE 0.7:9 Perform ‘focus’,pp,qq,rr
332691 - RULE 0.7 exit rules, skip Outgoing Action
332691 - IN 0.8 Perform Focus(0,2,20)
332691 - RULE 0.8:2 Perform ‘Focus-check’,pp,qq,rr
332691 - IN 0.9 Perform Focus-check(0,2,20)
332691 - 0.9:1 Log Focuscheck being performed
332699 - OUT 0.8 Activating app: ‘Cubase13.exe’
332836 - IN 0.11 On app activated: ‘Cubase13.exe’
332836 - RULE 0.11:1 assignment: (gc=1) = 1
332836 - 0.11:2 Log Cubase is Focused gc=1
332941 - OUT 0.9 Perform ‘Getfocus’ with 3 parameters, delay:250 millisec
332941 - IN 0.10 Perform Getfocus(0,2,20)
332941 - RULE 0.10:1 assignment: (ss=gc) = 1
332941 - 0.10:2 Log Getfocus returned 1
332941 - RULE 0.10:17 assignment: (ga=0) = 0
332941 - RULE 0.10 exit rules, skip Outgoing Action
334702 - IN 0.12 On app deactivated: ‘Cubase13.exe’
334702 - RULE 0.12:1 assignment: (gc=0) = 0
334702 - 0.12:2 Log Cubase is Not Focused gc=0
