Hello, I would like to know if it is possible to control 1 SQ-6 allen & heath in midi with the ethernet port of the SQ-6, knowing that I want to be able to record and "read" the movements of the faders of the SQ-6 and also be able to synchronize the effects of SQ-6 to the bpm of my sequencer?
Hi, yes if you have the proper ethernet software on the controlling host (usually provided by Allen and Heath) , you should be able to do this. Also BomeBox has the capabilitity to translate MIDI for use with certain Allen and Heath devices since BomeBox firmware version 1.2. This includes the SQ series.
BomeBox supports Bome Network (WiFi and/or ethernet), USB (class compliant), MIDI DIN, Serial, USB Querty keyboards, and specific Allen and Heath Network MIDI.
https://www.bome.com/products/bomebox
