hi!
i’m interested in this as well, would it be possible to have control over the fixed velocity value with a midi CC message?
Hi, and welcome back!
I moved this to a new thread. Please find the attached example.
The first translator handles setting a new velocity value in the global variable ga
The second translator accepts a note-on at any velocity and then outputs the velocity that was stored in global variable ga.
I put a MIDI through path so that any other message pass through untouched. In this case this is also true with note-off messages since I don’t have a translator for that. Typically note-off message velocity doesn’t matter (most of the time). If it does, another translators would need to be added.
Note-Velocity-Controlled-by-CC.bmtp (1.3 KB)
Hey Steve thank you I will try it very soon!
I didn’t know that the message could pass between the translators using Rules.
Only global variables will be accessible by multiple translators.
Since qq is a local variable I have to move it to ga which is a global variable.
To learn more about how variable work, press F1 while in MT Pro to look at the manual.
Thank you for the great support, I mainly use the Bomebox to do SYSEX/CC conversion, so I never needed that global variable feature, but I’m very happy to discover it, it opens up a lot o possibilities. Best,
