Hello from Paris. Is anybody has an experience piloting daVinci Resolve 16 via Loupedeck plus and Bome ?
As a photographer I use it on Captureone pro but wonder whether this could be a good surface for resolve. (13 knobs with a click press, big knob to search edit?, 8 cursors for 8 colors,Hue,luma, and many more : https://loupedeck.com/en/products/loupedeck-plus) Loupedeck team answer that they will not develop template for davinci as blackmagis wont release the API infos and protect their market (you can purchase control surface from Blackmagic strating over than $1000 even a keyboard is rated $999 in France ), Anyway, as loupedeck market is more lightroom and premiere and the product seems to be replaced soon by a new version with oled touchs and other configuration, I mabye rather sell it. What are your opinions ? Thanks
As far as I can tell, Loupedeck is not a MIDI controller yet is set up with its own HID (similar to keyboard or mouse but with its own API). I've had some success with getting things working with MIDI controllers but not any success with using MT Pro with Loupedeck. With that said, if it sends or receives class compliant, then MT Pro should be able to handle that and convert to mouse, movements, clicks and keystrokes that Davinci Resolve should be able to use.
Hi, this guy (see link below) is working on making the Loupedeck+ compatible with Resolve, currently Resolve 16 on Windows, but he says his software is cross platform. I have just written to him to offer my help in making it cross platform as I am more of a Mac user.
Art Lasovsky
Cheers,
Damien
Hi I don’t think Loupedeck+ is MIDI is it? Not sure why you are posting here. Maybe because a lot of people like to use MIDI controllers to control Resolve which doesn’t support MIDI (except for Fairlight).
Of course MT Pro can send mouse and keystroke movements by translating from MIDI.
It is a midi controller. I managed to map it for clicks and scrolls but it is so inconvenient and hard to map everything, and mostly the main functions for editing are not working well…
I would also like support for Resolve with the LD+
If you can show me one MIDI message you want me to map, I could probably give you an example. However since I don’t have a LD+, I would have to use one of the controller I own to provide an example so could not test it with LD+.
i found this:
I hope it is useful.
BR
Markus
Ah, so it appears that the Loupedeck is likely a non-MIDI (HID) device and the plugin is software to convert the Loupedeck HID protocol to MIDI for applications that require MIDI.
Thanks Steve,
i found this:
Thanks, I’m sure other Loupedeck users will appreciate this.
