Device conflict, Push, Live and MTP
Im trying to use the user mode of ableton push as controller for my sequencer. but im having issues with ableton and MTP fighting for the push user output 2. it continually drops out and is causing looped messages.
how should i position the Push in relation to Live given i need it for MTP also. how can i streamline it?
i need to send with pad press from push (sends both on and off..) a message to sequencer and a message back to push user port to give light feedback (not sure if it needs to go through ableton or not).
but in order to have lights on the pad in the first place i need to send Note information from Lives clips (unless there is another way?)
so need:
-push user port--> MTP-->Sequencer
-connection between Live and Push to send light info to pads (note and velocity constantly, would like to toggle them for mutes but cannot figure out how to toggle between turning a note on and turning it off in live.
seems simple and i have had it working but its buggy.
im sure there is an easier way around this using routings but im very new to this and am struggling. give me a point in the right direction?
1586324542990_Queen-Street1-TrMuDublights.bmtp
should i set up routing so that BMT is between live and the push entirely? so in lives midi settings i would be enabling track and remote for BMT input and output ports instead of Ableton push ports? or is it better to run it as Ableton Intended with it selected in the midi preferences? when i have it set like this the Port status in BMT changes to pending of the Push…
Run everything through MTP.  Any static routes use the MIDI routing capability.  Start MTP before starting Ableton Live so it doesn't try to use the Push ports directly.  If you want you can route specific things to different virtual ports to Ableton Live.
Review the below tutorial on how to manage device selection at the project, preset and translator level.  I usually do most of the device selection at preset level.
https://youtu.be/KunN2A1rKMY
Anything you do with a translator, use swallow so that it doesn't also go through to the default static route.
If you exit rules in a translator without executing outgoing action, it will never be swallowed. It will still send the original incoming message out the static route.
That is the short version. I'm not at my computer now (just a Chromebook) so if you still have questions. Check back with me tomorrow and I can look at the project file you posted and perhaps give a few more tips.
What is best practice with clock signals as far as routing goes? how should i route it at the project or preset level? If my squarp sends clock and transport over usb how best to route this so it has an equal path to all gear and DAW(live)?
should i set up routing so that BMT is between live and the push entirely? so in lives midi settings i would be enabling track and remote for BMT input and output ports instead of Ableton push ports? or is it better to run it as Ableton Intended with it selected in the midi preferences? when i have it set like this the Port status in BMT changes to pending of the Push.....
Everything through MT Pro.
Push User -> MT Pro Translators -> Squarp
Push Ableton -> MT Pro MIDI Router -> BMT 1 -> Ableton Live
Ableton Live -> BMT 1 -> MT Pro MIDI Router -> Push LED Feedback
On your push mapping preset, I would set the default inputs and outputs at the preset level instead of at the translator level as if you make routing changes, you will have a lot less work to do.
See this tutorial.
Just use MIDI routes in MT Pro for clock signals to the devices you want to provide clock.
Note since Push (I believe also has Audio), it should flow to Ableton through the ASIO driver directly.
im still having issues running Ableton and Push 1, with MTP. I start the program first then turn on controllers (push and squarp pyramid on usb only at this stage) for it to connect to them the ppush ports unexpectedly closed and remain pending and greyed out.
i have already set up aliases in MTP and in Ableton to reference Push. so they dont commincate directly except i cant stop Ableton automatically mapping the Push as a control surface with its default ports even though i have surface 1 automatically set as 1 Push from BMT1 and Push to BMT1.
Push port 1 out goes to POrt 1 out alias and then this goes to Bome virtual--> BMT1 for Ableton to recognize it.
Push User port out goes to port 2 out alias then to bome virtual 2--> bmt2
but now i am not receiving anything from push and i can send anything to it.
i had it working yesterday but when i restarted today it wouldnt work. this device conflict began.
i have tried many routings but am lost. can someone take alook and tell me where ive gone wrong?
do i need to set up some forwarding translators from push to ableton? on both ports?
i tried with sysex but it changed nothing..
do i set the Default Push ports to active at the project level aswell as creating an alias? does it need to be active for the alias to work?
my input ports now show 3 ports from live wher before it was only 1..
now there is Push, Push 1, Push 2.
normally there is a port 1 and User port (2).. but notmatter if i delete them they come back. i have searched in my rules and translators and cant see any references to it...
i am trying to send notes to Push user port to light the pads (on timer from MTP) while also triggering cc and note messages to control sequencer and midi input channel chnage from my cp-33. as i said yesterday it was all sweet and this morning nada....
any assistance greatly appreciated
1586572147248_Queen-Street1-TrMuDublights.bmtp
Hi looking at your project file, it looks like you have defined the following aliases. It is possible that you may have multiple aliases sending or receiving from the same physical port or device.
You have 7 input aliases and 7 output aliases. I\'m unclear how you want them assigned. Particularly
Ableton Use Port Alias! vs Ableton port 1 IN Alias vs Ableton Push 1
If you have an input port from Ableton Live for both user port and another port that should be 2 inputs
If you have output port to Ableton Live user and another port that should be 2 outputs
If you have input and output from Pyramid, that is 2 more ports (1 input and 1 output)
You have an output called Clock is this the same as the output port to Pyramid?
Pyramid MIDI USB input and output Aliases. Are they the same as the 2 Pyramid Aliases?
What is CP-33
My guess is you need to eliminate many of these aliases in your project and combine them in to the minimum needed.
As I see it you need
Inputs
From Push User
From Push Ableton
From Ableton Live (BMT1)
From CP-33 Channel Changer
Pyamid (for clock)
Outputs
To Ableton User (BMT 1)
To Ableton 2 (BMT 2)
To Pyramid Squarp (For channel changing)
To Push Lights
Or 5 inputs and 4 outputs
So deleting some aliases seems to be in order here. You will manually need to go to any translators or presets that use the aliases you do not want otherwise, you will continually get prompted to assign them.
Once you delete unused aliases in the project file, you can clear all aliases in settings menu and re-assign them all over again. If an unwanted alias pops up again don\'t re-assign it. Go the the project and delete the un-needed alias again then clear aliases.
At the project level check all aliases you will be using in the project otherwise, Ableton may try to take it over again.
It may be helpful if you create a diagram for yourself with the alias names and their port names so that you can keep the aliases straight. It would also be helpful to me if you come back to me with more questions.
thanks for your help steve!
i tidied up my aliases but Im still confused by how to use them and if i have done it correctly.
cp-33 is my piano controller, i want to have it chnage midi channel with a note on from push (cp-33 Ch Changer)
do i need to join two sources in the router section if i have a translator set up that requires them or is the translator enough?
do i also need to check the boxes next to the real input sources in the project default midi ports or just the aliases?
the Clock to BMT 3 Channel i created to allow connections for gear to the clock signal from my sequencer (squarp pyramid usb, midi clock not MTC). should i just reference the pyramid alias for the all the gear that needs clock? i did this as i thought it would be more stable to reference midi clock this way. is this the case?
should i route the aliases of push going in and out of ableton through the Bome virtual port1+2 --> Bome Midi Translator Virtual out 1+2?  or just straight out BMT 1 and 2??
what is the best order to start software and controllers in? if i start the squarp it disconnects the push channels in MTP but only one reconnects. and if i start push push its the opposite. i start MTP first then controllers then live, its conflicts, if i chnage the order it conflicts. hopefully this is just due to my alias dilemmas.
for the light feedback (push Lights) i am sending note on to push 2 to light the pads.
Im trying to have a few different types of light responses depending on what its mapped to. track select (top 16 pads) i want only the last pressed pad to be a different colour and for mutes i want them to toggle between two colours. i have achieved the mute toggling but it is now not working due to this conflict and my errors. is there a way using rules to set up the active track light?
thanks steve
much appreciated!
1586578999303_Queen-Street1-TrMuDublights.bmtp
just to add im getting 3 push ports appearing on the input and the output Push, Push1,and Push 2. they come back if deleted. this causes the routings to get altered. what does that imply if there is an extra port? something in my MTP project or in Live/on my computer?
also question about aliases, if i have already assigned in the output do i need to link them in Midi route also or will this create double messages.
what ports should i assign to the default midi ports of the project? all the ones i use in it that say open next to them? or only the ones i want to control on a project wide level?
Look at this file not the previous upload. i deleted all midi routings between usb ports and their aliases. does the use of routing and aliases look ok?
1586581818908_Queen-st.bmtp
Hi, could you diagram how you want things connected? In the diagram, put the the aliases you are assigning and the actual port names. This will put things straight in my mind on how to do this in MT Pro.
If aliases are “showing up” again. it means you still have them defined in your project file. You need to rename them back to another assigned alias, the do the clear alias routine. Then when you re-open the project file, you should only be prompted for the aliases you need. If you are prompted for aliases that you thought you had deleted, you need to go through and change those aliases to one of the ones you want to continue to use.
Oh on on your other question. Only check the aliases you want for input and output and not the actual device ports. If you check both, you may get duplicate messages going to that port.
I started this diagram but got confused on how you want things set up. So I\'d like to ask you to complete. You can just draw on a piece of paper and scan if you would like.
What I need to see is the actual port names along with their aliases. This should help you keep things straight. I would not assign multiple aliases to the same physical port as this will confuse things later on.
Also, a screen shot of your MIDI alias assignments might be helpful.
![](upload://frul5zv6BgptBWouMxUCfnDfHcN.png)
ok so i cleared the aliases like you said an redefined them i created lots more last night in prepartion for setting up the studio alot of the set ups will be identical so if you could help me with one of each type that would invaluable! much appreciated mate!.
I drew a basic plan showing the bones of the setup and the types of inputs I want from what. I have a bome box on the way but for now its into the computer with a usb hub and a Motu Express XT 8x8 midi interface.
There are a few types of devices i want to set up rather than draw the entire studio if you show me how to do one of each sort i can hopefully replicate it.
1. Devices on USB hub, eg Push, Tb03, CP-33(piano, Channel changed by push control)
        - synths sending notes and cc's to squarp
2. Software Ableton, Push needs to communicate with Ableton(automatically maps to Ableton push orts not BMT 1. causing issues everytime i start Live) and Squarp sending cc's and notes. it doesnt receive any info back from either source.
3. Midi Devices Juno 106 DIN out---> Motu -->set k0 to incoming channel value then Output on ch 1(note on off,cc#, Mod,Pitch bend) -->Squarp usb Alias
     --do i make an alias here for the DIN devices?  i did for most instruments last they are all the inputs you will see in my midi router list.
4. Squarp output sends back data to MTP--> if Ch 1 --> input channel=ja output channel =jb, if ja==1 then jb=k0 (MTP change back to channel k0)-->Juno 106 Alias-->motu-->Juno 106
Im trying to set up the following functions:
1. Push  Alias (port 1 and user port) USB hub <-->BMT 1 Ableton
     --port 1 out to alias<--> Ableton Push Port 1 out Alias<-->BMT 1
                           all ableton control
     --port 2 User port <--> Ableton User Port In Alias!<--> MTP output to Squarp input Alias
                            -Control of squarp and Cp-33 Ch Changer by sending cc and note info
    ---MTP send note on to light pads--->Ableton Push Port 1 Out Alias
                       -trying to create track selct light where only one track is "selected" at a time.
                        --pads are all yellow. changes velocity when pressed. when another key pressed, returns to yellow  how could i go about this? the mute lights toggles on and off but cant get this function.
Thanks heaps mate here are some screen shots and a photo of the plan (sorry for my handwriting i was a chicken in a past life)
1586648939982_Queen-stalias-clean.bmtp
![](upload://k5XWWtwoLauBtGQFTeduCcddcqK.jpeg)
![](upload://q3KBwiRb2joGhBV9u4iZkZyEXsA.jpeg)
![](upload://uZgGqVjE17CtDuJV3MkFTG6jA3b.jpeg)
Wow, I will have to digest this a bit.
1) In Live, are you using MIDI remote Script (top section of MIDI) for port 1, user port or both?
2) Does Squarp send to Ableton as just an instrument (track) or also as a control surface?
3) How is your BomeBox going to play into this? What devices will be connected. Is BomeBox replacing MOTU?
4) Is your USB hub powered? (it should be since you have 4 devices connected)
General Guidlines
1) Define only one alias per device. Creating multiple aliases for the same device will bite you sooner or later.
2) MT Pro opens and closes ports automatically as they are needed. If you want to hold a port open all of the time, you should put a check mark by that port's alias at the project level to ensure the port is always held open. Do not also put a check mark by the physical port. The alias will handling the control of the physical port.
3) Only use thru paths in the static router if:
Most everything needs to go through that path untouched
You have variable length Sysex that you cannot manage with translators
Note that if you have a static path defined EVERYTHING will go through that path unless you have a translator that executes an outgoing action and the option "SWALLOW" is set.
For instance, if the translator has a rule like "if xx==yy then exit rules, skip outgoing action", then swallow will not work. In this case you need to set up another translator with the exact same incoming trigger and an outgoing action of none. Otherwise the message will still go through.
4) Organize your presets by device. Put all translator with the same input and output path under it's parent preset. You can have presets that have multiple output devices. If so, use their aliases, not their physical port. If you have a few exceptions (maybe one or two translators). You can override the preset (and project) paths within a translator, but do so sparingly.
5) Give your aliases meaning full names so you don't trip yourself up. I usually name my aliases "From xxx" or "To xx" to make it clear whether it is an input or output alias. Using a term like "MIDI DIN", may end up being confusing even if the device is currently on a MIDI DIN port. Maybe in the future it will be on a network or USB port and so naming it MIDI DIN would be confusing if you change to a configuration like that.
For your aliases based on the diagram I will use something like:
From Push Port 1
To Push Port 1
From Push User Port
To Push User Port
From CP-33
To CP-33
From TB-03
To TB0-03
From Pyramid Squarp
To Pyramid Squarm
From Live Control
To Live Control
From Live Instrument
To Live Instrument
From Juno 106
To Juno 106
For Clock I would just set up a preset (or maybe just a single translator) with defined inputs and outputs
Input: From Pyramid Squarp
Outputs:
To Live Control
To Juno 106
To TB-03
Notice I picked the Aliases from existing ones above.
For me, I alway prefer to use translators and seldom every use static thru paths. I've been bitten too many times in the past with the Swallow rule I mentioned earlier and prefer to have absolute control.
Thanks so much mate!
here is the answer to those questions
  1. In Live, are you using MIDI remote Script (top section of MIDI) for port 1, user port or both?
    In Live i will use Port 1 to transport normal Push control of ableton. and the user port (port 2) is controlling squarp and cp33 channel changer via MTP
  2. Does Squarp send to Ableton as just an instrument (track) or also as a control surface?
    Squarp only sends instrument to Ableton
  3. How is your BomeBox going to play into this? What devices will be connected. Is BomeBox replacing MOTU?
    Bome box will be connected to powered class compliant USB hub (on its way) and will handle all the midi
    it will not replace the Motu the motu will act as a midi merger and router to transmit 5 pin midi Devices to the Bome box. ideally i would like to run the set up with or without a computer(as im just recording audio and midi on computer mostly so dont need it to jam Squarp handles all sequencing) but it seems i cant access push without live running? is this the case or is it just due to this midi mess i made?
  4. Is your USB hub powered? (it should be since you have 4 devices connected)
    yes
thanks steve hope this helps
The Motu will merge all 5pin midi signals to two midi cables into the bomebox for routing, channel toggling etc
made those changes but still having problem with Live taking over Push...
Im still having a conflict issue with Live, the Squarp and Pyramid. the ports drop out and remain pending when i start another device, ie if start push squarp drops out, if start live push drops out from MTP. keep chasing my tail..
the only way i can see to stop Live automapping Push to it default ports is to remove its Remote midi scripts from the Ableton directory but this means i can use push to control live devices.. This stopped the auto mapping to default push ports but did not stop the problem in MTP.
should i use the midi router for the 'from Push Port 1" to BMT 1 that goes to Ableton? as i dont use this port at all in my mapping file (only to control Ableton internally, which i cant do without the remote midi script in place...)
I will get it working how i want it then save and restart the comp to check and it happens again. the ports stop sending. its like a usb conflict in my computer.
The "to squarp" port will often remain closed even when it says in the error monitor that it has reconnected..
i tried to implement all of what you have suggested and it helped alot. i was really in a mess before but now i feel like its well organised but its not working..
Thanks again for your help Steve
1586690930859_Queen-st-latest.bmtp
Hi, I’ll take another look. I also asked Florian to get you involved in the current Beta program as I have one one occasion had problems with MT Pro ports closing themselves and Ableton Live “stealing” them while they are closed.
If you are not doing any custom scripting or directing traffic to Ableton LIve from other than Push, then yes, you should be able to bypass MT Pro with the Push 1 port, however I suspect you are also directing MIDI clock to push from your Squarp to Ableton Live. Maybe we can open up a separate virtual port from MT Pro to send MIDI clock signals to Ableton Live.
