Disable MTP Wants Attention
When booting up MTP it starts minimized but does the orange flashing thing because it wants attention for something. Think it happens whenever the error box is triggered with a message.
Orange Icon
Could you give us the ability to disable that please?
It’s incredibly annoying an unnecessary.
When you look at the error message, what do you get? It certainly makes sense to flag error messages if it affects the functionality of MT Pro.
I’m just assuming the reason for the orange taskbar blinking.
I don’t know what the actual trigger is.
When I start FLS it is set to boot MTP too. MTP is set to start as minimized.
MTP always has the orange blinking when it proxy starts from FLS (don’t remember if it also happens when manually starting it). The errors are the standard MIDI port issue as discussed before.
Error Box
Do you use these ports? If so, your project file will not work correctly. If not, you should probably uncheck them in your project file so they do not attempt to open.
If you do nothing and you are using the ports, does the error clear after a few minutes when they open correctly?
Hi @J.Boss , thanks for reporting this issue.
The taskbar icon should only blink if there is a dialog that MT needs to show. I believe in the current version that includes any errors to be reported.
Error handling will be greatly improved in the next version of MT Pro (due soon). Errors will not be force-shown, but the error log will be marked red.
