I would like to connect my Elation Midicon 1 to Dot 2 via Bome. Faders 1-8 also work and buttons A1-8 B1-8 and C1-8 I also know how to assign them.
What does not work the blackout button to use as this and the master fader. As well as the page buttons and the 3 knobs.
Could you capture the incoming MIDI in a log window of MT Pro for these knobs and buttons and post it here? If they do not send MIDI, then there is likely nothing we will be able to do, however if they do, then we could probably convert to note messages for Dot2.
I’m not sure if you can program the master fader. When I look at Remote Settings, it looks like it says that the function of the main executor buttons are fixed. I can see MIDI coming in so it must be something to do with what dot2 has to figure out. I’m not that familiar with dot2 other than determining which MIDI input to use and how to convert CC to note for dot2 in MT Pro.
I think you will need to review the dot2 documentation or discuss with the dot2 software manufacturer. I suspect that they may have disabled some functions for generic MIDI controllers and only support them on their hardware devices.
