When installing Bome Midi translator pro i get an error as is th e attached sceenshot. When I try to start Midi Translator nothing happens. When uninstalling kind of the same error appears, that the virtual midi ports cannot be uninsalled.
I tried reinstalling (after also uninstalling virtual midi) several times. No change. I also checked to force reinstalling virtual midi. What can I do?
Hi Niklas and Steve,
although the error message seems to be a problem with the virtual MIDI driver, it is an issue with creating the default virtual port after correctly installing the virtual MIDI driver.
We have identified the root cause and will post a fix very soon. Sorry for the inconvenience!
PS: I’ve removed your previous discussion in this forum topic in order to avoid misleading others who come here with the same problem.
