Hello,
I used my bome box for many years. This month, I changed some part of program. When I upload it iun to bome box, sometime the system works and sometimes program doesn’t start with the following message :
1133565: Loading project: 2025 - Presonus - Dlive V7.bmtp 1137035: This project file is not compatible with this program. (must be signed by the vendor) Please contact the vendor of this tool, or Bome Software, for more information. 1137112: Loading project from “/projects/2025 - Presonus - Dlive V7.bmtp”: Error loading project file: /projects/2025 - Presonus - Dlive V7.bmtp 1137648: save settings OK: last modified=2025-04-23 06:07:51 filesize=1028 filename:/etc/mt/playerheadless.bmts
I don’t know why. I paid licence in the past and no change on my PC.
Some idea ?
You are using the trial copy of Bome MIDI Translator Pro instead for the purchased copy. The purchased copy ‘signs’ the project file which is required for it to run on BomeBox. or
Perhaps you did some manual editing with a text editor of your project file. If you do this, the project file signature is invalid and it will not run on BomeBox. To fix this, simply open the project file on your computer with the fully licensed version, make a small edit and then save the changes. The project file with then again be signed.
If you are running the trial copy on your computer, use your Bome account where you can download the fully purchased version.
The Bome Account is not automatically created with purchase. Just create one here.
Normally, your product license and download will be automatically accessible. Only if you’ve used a different email address at time of purchase, just create an account with your current email address and then use the Add Product function in your user account to claim your license.
Note: after creating your account, your licenses will only be available after clicking the activation link in the activation email! You can also use the Lost Password function to activate your account.
Only when your account is activated, you can view your license(s), download the latest version, and add missing licenses.
Hi Steve, your right I use external notepadd++ to change adress because I have a lot to do. I did that for long time but first time I have this error. I try to do change into translator before and try to upload. it very usefull to be able to change texte or address in text editor. a good imprvemnet should be to have the id codify on 5 digit to change by block because if I have more than 10 transaltors, the code is outgoing1
outgoing11
outgoing111
outgoing2
…outgoing
if you code like this
outgoing00001
outgoing00002
outgoing00003
we have block and we can change text by block.
Regards
