I’m looking to get led feedback on my (Allen & Heath) K2 controller when record arming tracks in ableton. Tried to setup led toggles first in Bome but that doesn’t seem to respond, although they work when mapped to other functions. Is it even possible to get this working in Ableton? Im not an expert in midi scripts.
Hi, I think you will need to set up Ableton Live with a MIDI Remote script to get either Solo or Record arm to work. You can learn MIDI for them but they do not echo back any MIDI messages. Pans, Faders and Track Select do, however.
Go to Remotify.io if you cannot find a MIDI remote script that will work and you want to create your own.
Alternatively you could use a different (already built) MIDI remote script and put the output through Bome MIDI Translator pro to translate and light up the LEDs that you want.
