I receive from Korg ... CC 71 for example.And I need to execute to vsti with delay (0.3,0.5 seconds ) . I add delay to control....but nothing ...Any idea ? Thanks
Hi Florin,
Please post the project file or example file showing the problem and I will take a look.
Hi, please see the example project file where I have an incoming note that triggers a CC with a 300ms (.3 second) delay.
1570196143332_Korg-Note-to-CC-w-Delay.bmtp
I did the same,like in picture,no delay .
Could you post the log with the timestamp. You will notice the 300ms delay on the screen shot I posted.
This is my CC …. I use the MIDI direct in paralel,but I block the control from Midi IN (from software) ,so the vsti receive only the CC from Bome
1570262954355_CC71.bmtp
The issue is you are looking for an incoming value of pp, however since pp is a local variable the value is not defined and could be anything. See first screenshot.
What you need to do is make incoming “any value” and “set value to pp”. Then you will get output delay. See second screenshot.
Thank youuuuuuuuuuuuuuuuuuu !!!! I told you…..you are a God of MIDI !
I’m glad we got it working!
