Is there a way to export my midi backups from SendSX to a external folder and then import the same?
IE PC failure…
Thx in Advance
IE PC failure…
Thx in Advance
Yes,you can save them as either binary .syx files or save as text.
SaveAs are available on the file menu of SendSX.  They will be exported as text if you choose type text in the dialog box.
