In order to find a double use of a global, I dug into the Export to text so I could use search features in an external text editor. In doing so, I found discrepancies with the output of the feature. Have there been any reports of inconsistency in this regard? More specifically, I’m seeing a translator name in the text file that does not exist in the project. I believe I renamed the translator and the old name name is appearing in the text file. I tried to use the numbering scheme to track it down but that is also incorrect in the text file.
BTW, the project is fairly large. Hundreds of translators.
OK, thanks. What editor are you using to edit the file? Are the deleted entries toward the end. Maybe the editor you are using is not reading the endo of file mark (which should be control z ), so it is showing out until the end of the next block.
