Hello, I didn’t find the good topic, so I’m asking the question, how to configure a fader or a knob to send cc messages. I use a APC mini, Thx !
The APC-MINI faders (it has no knobs) already sends CC messages.
CC 0x30 (48 decimal) through CC 0x37 (55 decimal). So my guess is you may just want to translate them to different CC’s.
Thx, I have to send the message to a eventide pedal, and I need to change the channel of the message and the CC number.
Hi, the below example should provide what you need.
Here I take the incoming CC 48 on MIDI CH 1 (first fader on APC-MINI), and translate it to CC58 on MIDI CH 5.
I set up my aliases as below but you may need to re-assign them to your needs. You can use the MIDI Menu → Edit Project Port Aliases to do this.
Change-CC-and-MIDI-CH.bmtp (1018 Bytes)
Thank you very much, it’s better late than never for asking !
My pleasure!
