Filter messages using swallow function
Hello,
Hope you’re good.
I’m trying to use the MT Pro to filter messages on my bome box.
I’d like to be able to filter out CC messages on certain channels which are sent from Ableton on my laptop over network to the bome box and then output to a keyboard connected to the DIN OUT port on the bome box.
I’ve set my computer network connection as an alias for the INPUT, the keyboard as another alias for the OUTPUT, assigned them in the bome box browser and used the following settings in MT Pro but the CC messages are still getting through according to my MIDI monitor.
I have not set a Thru connection.
It feels like I’m missing something very simple. Any advice you could offer would be much appreciated.
Kind regards,
Jamie
Could you show me:
  1. A screen shot of the Ableton LIve MIDI configurations settings.
  2. A screen shot of of your Bome MIDI Translator Pro alias settings.
  3. if there are any rules in your example translator. Can you also show those?
Thanks Steve,
There are no rules applied in the translator.
In Ableton Live, disable all tracks except Bome MIDI Translator 1.
In Bome MIDIT Translator Pro, set you Input alias to Bome MIDI Translator Virtual Port 1 and Instrument to BomeBoxTools: BomeBox DIN.
Then it should work. Basically in the current configuration you are bypassing Bome MIDI Translator Pro by sending directly to the BomeBox port. You want Ableton to only send through the translator in Bome MIDI Translator Pro.
Thanks for your reply Steve.
Is it not possible to do this without running the bome translator and using just the bome box + MT file uploaded?
Kind regards,
Jamie
Yes, if you are running on the BomeBox, then upload your project file and set your alias on your BomeBox for Computer to your computer name and Instrument to BomeBox DIN. Then in Ableton LIve, you should have the track output send to Your BomeBox Name (BomeTools).
Then the project on your BomeBox will block the messages sent to your device. However if you want it to let other MIDI pass you will need to set up a route (thru path) in your project to let other messages through.
Thanks Steve, thats brilliant.
My error was routing to the Remote Direct MIDI DIN in Ableton instead of the main bome box as well as failing to have a MIDI thru route enabled for everything else.
Thanks very much for your help.
Kind regards,
Jamie
Glad it worked!’
