Hey guys
I'm trying to get light feedback on My Push 1 controller used standalone through a hub into a Bomebox. I need help with the light feedback and setup side of it.
The basics of the push layout are
The top two rows of pads are track select button for my sequencer (squarp Pyramid). The next 16 are track mutes, next 8 are 'sequence' selectors. Sequences on my sequencer are basically track mute states.
Basically what I'm after is the
--'active' track in the top 16pads to change colour when pressed. Then when I press another it changes back. So only the selected track is a different colour.
--when a track is selected as above corresponding mute pad changes colour to show a track is on that channel
--getting trickier but can I create global variables that can be updated and 'remembered' so when I press a sequence button it's corresponding track mute states are shown in the mute section?
-pads colour changes with oress/ pressure but returns to default colour after.
In order to get a light you send a note on message to the push. Velocity decides colour. I currently set colours for pads as global variables. And send out on a timer.
This is great software and I have only scratched the surface as to what it's capable of. It's achieved exactly what I thought midi was 15 years ago. School me. Please
All help much appreciated
Brett
