I’ve downloaded Bome MIDI Translator classic to use in FFXIV. I used a bmtp file recommended in a video guide and on the first day of using it everything worked fine - keystrokes output correctly.
Any subsequent attempt to use the software won’t output a keystroke. I get the MIDI in light flashing when I press a key on the midi keyboard but no Key out
By default, outgoing keystrokes are suppressed if Bome MIDI Translator is the currently application with focus. Focus on any other application and it should work.
You can change this behavior in the Options Settings menu.
