i cannot save my projects anylonger. please any sophisticaded help me!
this is inside the hs_err_pid8000 textfile
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x199c4349, pid=8000, tid=4580
# JRE version: OpenJDK Runtime Environment (13.0.2+8) (build 13.0.2+8)
# Java VM: OpenJDK Client VM (13.0.2+8, mixed mode, serial gc, windows-x86)
# Problematic frame:
# C [mt.dll+0x44349]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# https://github.com/AdoptOpenJDK/openjdk-support/issues
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- S U M M A R Y ------------
Command Line: -Dbome.exe=C:\Program Files (x86)\Bome MIDI Translator Pro\MIDITranslator.exe
Host: 13th Gen Intel(R) Core(TM) i7-13700HX, 24 cores, 31G, Windows 10 , 64 bit Build 26100 (10.0.26100.3037)
Time: Sat Feb 22 14:53:43 2025 Mitteleuropäische Zeit elapsed time: 89 seconds (0d 0h 1m 29s)
--------------- T H R E A D ---------------
Current thread (0x15d8c800): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=4580, stack(0x19880000,0x19980000)]
Stack: [0x19880000,0x19980000], sp=0x1997e778, free space=1017k
Native frames: (J=compiled Java code, A=aot compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [mt.dll+0x44349]
C [mt.dll+0xf0193]
C [mt.dll+0xf25ca]
C [mt.dll+0xa93b1]
C [mt.dll+0xb1b3d]
j com.bome.mt.jni.ProjectJNI.saveProject(Ljava/lang/String;)Z+0
j Z.a(Ljava/lang/String;)Z+28
j Z.q()Z+226
j Z.a(Las;Ljava/awt/event/ActionEvent;)V+223
j as.actionPerformed(Ljava/awt/event/ActionEvent;)V+13
j javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+84 java.desktop@13.0.2
